阅读:2456回复:0
PHP操作Zip
更多 发布于:2012-09-12 06:54
<?php
     class phpZip
         private $ctrl_dir     = array();
         private $datasec      = array();
        // $archive  = new phpZip();
        // $filelist = $archive->visitFile(?????.??);
        // print "???????е????:<p>\r\n";
       // foreach($filelist as $file)
        //     printf("%s<br>\r\n", $file);
       var $fileList = array();
        public function visitFile($path)
             global $fileList;
           $path = str_replace("\\", "/", $path);
          $fdir = dir($path);
           while(($file = $fdir->read()) !== false)
              if($file == '.' || $file == '..'){ continue; }
                $pathSub    = preg_replace("*/{2,}*", "/", $path."/".$file);  // ?滻?????б??
                $fileList[] = is_dir($pathSub) ? $pathSub."/" : $pathSub;
            if(is_dir($pathSub)){ $this->visitFile($pathSub); }
           $fdir->close();
           return $fileList;
        private function unix2DOSTime($unixtime = 0)
            $timearray = ($unixtime == 0) ? getdate() : getdate($unixtime);
           if($timearray['year'] < 1980)
              $timearray['year']    = 1980;
                $timearray['mon']     = 1;
                $timearray['mday']    = 1;
                $timearray['hours']   = 0;
                $timearray['minutes'] = 0;
               $timearray['seconds'] = 0;
            return (  ($timearray['year'] - 1980) << 25)
                   | ($timearray['mon'] << 21)
                 | ($timearray['mday'] << 16)
                   | ($timearray['hours'] << 11)
                   | ($timearray['minutes'] << 5)
                  | ($timearray['seconds'] >> 1);
        var $old_offset = 0;
        private function addFile($data, $filename, $time = 0)
            $filename = str_replace('\\', '/', $filename);
           $dtime    = dechex($this->unix2DOSTime($time));
           $hexdtime = '\x' . $dtime[6] . $dtime[7]
                    . '\x' . $dtime[4] . $dtime[5]
                     . '\x' . $dtime[2] . $dtime[3]
                       . '\x' . $dtime[0] . $dtime[1];
            eval('$hexdtime = "' . $hexdtime . '";');
           $fr       = "\x50\x4b\x03\x04";
          $fr      .= "\x14\x00";
          $fr      .= "\x00\x00";
            $fr      .= "\x08\x00";
          $fr      .= $hexdtime;
           $unc_len  = strlen($data);
           $crc      = crc32($data);
          $zdata    = gzcompress($data);
           $c_len    = strlen($zdata);
           $zdata    = substr(substr($zdata, 0, strlen($zdata) - 4), 2);
           $fr      .= pack('V', $crc);
            $fr      .= pack('V', $c_len);
           $fr      .= pack('V', $unc_len);
          $fr      .= pack('v', strlen($filename));
           $fr      .= pack('v', 0);
          $fr      .= $filename;
           $fr      .= $zdata;
            $this->datasec[] = $fr;
            $new_offset      = strlen(implode('', $this->datasec));
           $cdrec  = "\x50\x4b\x01\x02";
           $cdrec .= "\x00\x00";
            $cdrec .= "\x14\x00";
         $cdrec .= "\x08\x00";
          $cdrec .= $hexdtime;
           $cdrec .= pack('V', $crc);
            $cdrec .= pack('V', $c_len);
            $cdrec .= pack('V', $unc_len);
            $cdrec .= pack('v', strlen($filename) );
           $cdrec .= pack('v', 0 );
           $cdrec .= pack('V', 32 );
            $cdrec .= pack('V', $this->old_offset );
          $this->old_offset = $new_offset;
            $cdrec .= $filename;
           $this->ctrl_dir[] = $cdrec;
        var $eof_ctrl_dir = "\x50\x4b\x05\x06\x00\x00\x00\x00";
        private function file()
             $data    = implode('', $this->datasec);
             $ctrldir = implode('', $this->ctrl_dir);
             return   $data
                    . $ctrldir
                  . $this->eof_ctrl_dir
                  . pack('v', sizeof($this->ctrl_dir))
                  . pack('V', strlen($ctrldir))
                  . pack('V', strlen($data))
                  . "\x00\x00";
       // $archive->Zip("????????????????", "ZIP????????");
         public function Zip($dir, $saveName)
             if(@!function_exists('gzcompress')){ return; }
             ob_end_clean();
             $filelist = $this->visitFile($dir);
             if(count($filelist) == 0){ return; }
                 if(!file_exists($file) || !is_file($file)){ continue; }
                 $fd       = fopen($file, "rb");
                 $content  = @fread($fd, filesize($file));
                 fclose($fd);
                 // 1.???$dir?????(./folder/file.txt???./folder/)
                 // 2.??????/?????(/file.txt???/)
                 $file = substr($file, strlen($dir));
                 if(substr($file, 0, 1) == "\\" || substr($file, 0, 1) == "/"){ $file = substr($file, 1); }
                 $this->addFile($content, $file);
             $out = $this->file();
             $fp = fopen($saveName, "wb");
             fwrite($fp, $out, strlen($out));
             fclose($fp);
         // $archive->ZipAndDownload("????????????????");
         public function ZipAndDownload($dir)
             ob_end_clean();
                 fclose($fd);
             @header('Content-Encoding: none');
             @header('Content-Type: application/zip');
             @header('Content-Disposition: p_w_upload ; filename=Farticle'.date("YmdHis", time()).'.zip');
             @header('Pragma: no-cache');
             @header('Expires: 0');
             print($out);
         // ReadCentralDir($zip, $zipfile)
         // $zip?????@fopen($zipfile, 'rb')?
摘自 lpdx111的专栏
