阅读:3519回复:0
PHP中soap的使用例子
更多 发布于:2012-09-12 06:55
php中soap的使用例子
php 使用soap有两种方式。
一、用wsdl文件
服务器端。
<?php
  public function HelloWorld()
      return  "Hello";
  public  function Add($a,$b)
      return $a+$b;
$server=new SoapServer('soap.wsdl',array('soap_version' => SOAP_1_2));
$server->setClass("service");
$server->handle();
资源描述文件,可以用工具(zend studio)生成。其实就是一个xml文件。
<?xml version="1.0" encoding="UTF-8"?>
<wsdl:definitions xmlnsoap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:tns="http://localhost/interface/" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="soap" targetNamespace="http://localhost/interface/">
  <wsdl:types>
    <xsdchema targetNamespace="http://localhost/interface/">
      <xsd:element name="HelloWorld">
        <xsd:complexType>
          <xsdequence>
            <xsd:element name="in" type="xsdtring"/>
          </xsdequence>
        </xsd:complexType>
      </xsd:element>
      <xsd:element name="HelloWorldResponse">
        <xsd:complexType>
          <xsdequence>
            <xsd:element name="out" type="xsdtring"/>
          </xsdequence>
        </xsd:complexType>
      </xsd:element>
      <xsd:element name="Add">
       <xsd:complexType>
        <xsdequence>
         <xsd:element name="in" type="xsd:int"></xsd:element>
        </xsdequence>
       </xsd:complexType>
      </xsd:element>
      <xsd:element name="AddResponse">
       <xsd:complexType>
        <xsdequence>
         <xsd:element name="out" type="xsd:int"></xsd:element>
        </xsdequence>
       </xsd:complexType>
      </xsd:element>
    </xsdchema>
  </wsdl:types>
   <wsdl:message name="AddRequest">    <wsdl:part name="a" type="xsd:int"></wsdl:part>
   <wsdl:part name="b" type="xsd:int"></wsdl:part>
  </wsdl:message>
  <wsdl:message name="AddResponse">
   <wsdl:part name="c" type="xsd:int"></wsdl:part>
  </wsdl:message>
  <wsdl:portType name="TestSoap">     <wsdl:operation name="Add">
     <wsdl:input message="tns:AddRequest"></wsdl:input>
     <wsdl:output message="tns:AddResponse"></wsdl:output>
    </wsdl:operation>
  </wsdl:portType>
  <wsdl:binding name="soapSOAP" type="tns:TestSoap">
   <soap:binding style="document"
    transport="http://schemas.xmlsoap.org/soap/http" />
    <soap:operation soapAction="http://localhost/interface/Add" />
    <wsdl:input>
     <soap:body use="literal"
      namespace="http://localhost/interface/" />
    </wsdl:input>
    <wsdl:output>
    </wsdl:output>
   </wsdl:operation>
  </wsdl:binding>
  <wsdlervice name="TestSoap">
    <wsdl:port binding="tnsoapSOAP" name="soapSOAP">
      <soap:address location="http://localhost/interface/myservice.php"/>
    </wsdl:port>
  </wsdlervice>
</wsdl:definitions>
客户端调用
<?php
$soap = new SoapClient('http://localhost/interface/soap.wsdl');
echo $soap->Add(1,2);
二、不用wsdl文件
服务器
<?php
      return  "Hello";
      return $a+$b;
$server=new SoapServer(null,array('uri' => "abcd"));
$server->handle();
客户端<?php
try{
$soap = new SoapClient(null,array(
   "location" => "http://localhost/interface/soap.php",
   "uri"      => "abcd",  //资源描述符服务器和客户端必须对应
   "style"    => SOAP_RPC,
   "use"      => SOAP_ENCODED
}catch(Exction $e){
echo print_r($e->getMessage(),true);
