阅读:3827回复:0
android app首次进入的时候进行提醒操作
更多 发布于:2012-10-19 12:32
[html]
布局文件。外层用RelativeLayout 最后使用一张图片 并且android:keepScreenOn="true"
[html]
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
   android:layout_width="fill_parent"
   android:layout_height="fill_parent" >
   <LinearLayout
       android:layout_width="match_parent"
       android:layout_height="match_parent"
       android:layout_below="@+id/mycouponlisttoplayout"
       android:background="@color/loginbgcolor"
       android:orientation="vertical" >
       <LinearLayout
           android:id="@+id/loadingmycouponLayout"
           android:layout_height="30dp"
           android:gravity="center"
           android:orientation="horizontal" >
           <ImageView
               android:id="@+id/mycouponfootprogress"
               style="?android:progressBarStyleSmallInverse"
               android:layout_width="wrap_content"
               android:layout_height="wrap_content"
               android:layout_gravity="center_vertical"
               android:background="@drawable/spinner_small"
               android:contentDescription="@string/contentdesption"
               android:indeterminateBehavior="repeat" />
           <TextView
               android:id="@+id/mycouponTipMsg"
               android:gravity="left|center"
               android:padding="3.0px"
               android:text="@string/Loading"
               android:textColor="#ff000000" />
       </LinearLayout>
       <com.ejoy.customcontrol.XListView
           android:id="@+id/mycouponusalist"
           android:cacheColorHint="#00000000"
           android:scrollbars="none" >
       </com.ejoy.customcontrol.XListView>
   </LinearLayout>
   <RelativeLayout  www.atcpu.com
       android:id="@+id/mycouponlisttoplayout"
       android:layout_height="48dp"
       android:background="@color/black" >
       <TextView
           android:id="@+id/txtMyCouponTitle"
           style="@style/TopBarTextStyle"
           android:text="@string/mycentermyCoupon" />
       <Button
           android:id="@+id/mycoupondetails_normal_Btnreturn"
           style="@style/TopBtnReturnStyle"
           android:layout_alignParentLeft="true"
           android:layout_centerVertical="true" />
   </RelativeLayout>
   <ImageView
       android:id="@+id/mycouponhelpTip"
       android:layout_alignParentBottom="true"
       android:scaleType="fitXY"
       android:src="@drawable/mycoupontip" />
</RelativeLayout>
相关代码
[java]
helpImageView = (ImageView) findViewById(R.id.mycouponhelpTip);
       SharedPreferences sharedata = getSharedPreferences("fristrun", 0);
       Boolean isSoupon = sharedata.getBoolean("isSoupon", true);
       if (isSoupon) {
           helpImageView.setVisibility(View.VISIBLE);
       } else {
           helpImageView.setVisibility(View.GONE);
       helpImageView.setOnClickListener(new View.OnClickListener() {
           public void onClick(View v) {
               Editor sharedata = getSharedPreferences("fristrun", 0).edit();
               sharedata.putBoolean("isSoupon", false);
               sharedata.commit();
