阅读:2485回复:0
在.net封装了以后sql防注入解决办法
更多 发布于:2012-10-23 17:44
 网站不小心中招了,在网上整理了一个简单的防注入方法,和大家分享
web.config文件调用
SqlInPost.cs 放到app_code 目录下:
SqlInPost.cs
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Text.RegularExpressions;
using System.Collections.Specialized;
namespace SqlIn
/// SqlInPost 的摘要说明
public class SqlInPost:IHttpHandlerFactory
public SqlInPost()
// TODO: 在此处添加构造函数逻辑
public virtual IHttpHandler GetHandler(HttpContext context, string requestType, string url, string pathTranslated)
//得到编译实例(通过反射)
PageHandlerFactory factory = (PageHandlerFactory)Activator.CreateInstance(typeof(PageHandlerFactory), true);
IHttpHandler handler = factory.GetHandler(context, requestType, url, pathTranslated);
//过滤字符串
if (requestType == "POST")
Page page = handler as Page;
if (page != null)
page.PreLoad += new EventHandler(FilterStrFactoryHandler_PreLoad);
if (requestType == "GET")
if (page != null)
page.PreLoad += new EventHandler(FilterStrFactoryHandler_PreLoad1);
//返回
return handler;
//过滤TextBox、Input和Textarea中的特殊字符
void FilterStrFactoryHandler_PreLoad(object sender, EventArgs e)
try
Page page = sender as Page;
NameValueCollection postData = page.Request.Form;
foreach (string postKey in postData)
Control ctl = page.FindControl(postKey);
if (ctl as TextBox != null)
((TextBox)ctl).Text = Common.InputText(((TextBox)ctl).Text);
continue;
if (ctl as HtmlInputControl != null)
((HtmlInputControl)ctl).Value = Common.InputText(((HtmlInputControl)ctl).Value);
continue;
if (ctl as HtmlTextArea != null)
((HtmlTextArea)ctl).Value = Common.InputText(((HtmlTextArea)ctl).Value);
continue;
catch { }
//过滤QueryString
void FilterStrFactoryHandler_PreLoad1(object sender, EventArgs e)
try
NameValueCollection QueryNV = page.Request.QueryString;
bool isSafe = true;
for (int i = 0; i < QueryNV.Count; i++) { if (!IsSafeString(QueryNV.Get(i))) { isSafe = false; break; } } if (!isSafe) { page.Response.Write("非法传值!"); page.Response.End(); } } catch { } } public virtual void ReleaseHandler(IHttpHandler handler) { } //判断是否为安全字符串public bool IsSafeString(string p) { bool ret = true; string[] UnSafeArray = new string[22]; UnSafeArray[0] = "'"; UnSafeArray[1] = "xp_cmdshell"; UnSafeArray[2] = "exec master.dbo.xp_cmdshell"; UnSafeArray[3] = "net localgroup administrators"; UnSafeArray[4] = "delete from"; UnSafeArray[5] = "net user"; UnSafeArray[6] = "/add"; UnSafeArray[7] = "drop table"; UnSafeArray[8] = "update "; UnSafeArray[9] = "select"; UnSafeArray[10] = ";and"; UnSafeArray[11] = ";exec"; UnSafeArray[12] = ";create"; UnSafeArray[13] = ";insert"; UnSafeArray[14] = "and"; UnSafeArray[15] = "exec"; UnSafeArray[16] = "create"; UnSafeArray[17] = "insert"; UnSafeArray[18] = "master.dbo"; UnSafeArray[19] = ";--"; UnSafeArray[20] = "--"; UnSafeArray[21] = "1="; foreach (string s in UnSafeArray) { if (p.ToLower().IndexOf(s) > -1)
ret = false;
break;
return ret;
public class Common
public static string InputText(string text)
text = text.Trim();
if (string.IsNullOrEmpty(text))
return string.Empty;
text = Regex.Replace(text, "[s]{2,}", " "); //two or more spaces
text = Regex.Replace(text, "()+|()", "n"); //
text = Regex.Replace(text, "(s*;[n|N][b|B][s|S][p|P];s*)+", " "); //
text = Regex.Replace(text, "", string.Empty); //any other tags
text = text.Replace("'", "''");
text = text.Replace("xp_cmdshell", "");
text = text.Replace("exec master.dbo.xp_cmdshell", "");
text = text.Replace("net localgroup administrators", "");
text = text.Replace("delete from", "");
text = text.Replace("net user", "");
text = text.Replace("/add", "");
text = text.Replace("drop table", "");
text = text.Replace("update", "");
return text;
}&#8203;
