阅读:3891回复:0
[远程辅助工具]Remote Desktop Manager 7.970 - 远程桌面管理工具
更多 发布于:2012-10-25 14:58
[附件]
一个3389远程桌面管理工具,能否保存编辑删除你的远程桌面连接,带登陆的终端功能
Remote Desktop Manager is a small application used to manage all your remoteconnection. Add, edit, delete orgnanize or find your remote connection quickly.Compatible with Microsoft Remote Desktop or with Terminal Services, it's a goodreplacement of the Remote Desktops Snap-in
·当会话/vpn 使用输入凭据时,添加日志·测试版修复: 编辑/崩溃
