阅读:3386回复:0
[C++技术]用代码和UML图化解设计模式之《装饰模式》
更多 发布于:2012-10-30 10:30
这个模式看了两次,因为我有点不太理解,其实到现在也不太理解。
通过写代码,自我理解就是把对象重新装饰了一遍。通过继承同一个基类。而不用添加额外的类了。。。。
上图吧
通过修饰类达到我们想要的效果。修饰类通常初始化了基类。
[cpp]
// Decorator.cpp : 定义控制台应用程序的入口点。
/* @filename    Decorator.cpp
@author       wallwind
@createtime    2012/10/29 22:42
@function     命令模式
@email      */
#include "stdafx.h"
#include <iostream>
using namespace std;
class Widget
public:
   Widget(){}
   virtual ~Widget(){}
   virtual void show()=0;
class TextField:public Widget
public:
   TextField(int ix,int iy)
       :x(ix),y(iy)
   ~TextField(){}
   void show()
       cout<<"x:"<<x<<endl;
       cout<<"y:"<<y<<endl;
private:
   int x;
   int y;
class Decorator:public Widget
public:
   Decorator(Widget* widget)
       :m_widget(widget)
   virtual ~Decorator()
       delete m_widget;
   void show()
       m_widget->show();
       cout<<"Decorator:show()"<<endl;
private:
   Widget* m_widget;
class BorderDecorator :public Decorator
public:
   BorderDecorator(Widget* widget)
       :Decorator(widget)
   void show()
       Decorator::show();
       cout<<"BorderDecorator:show()"<<endl;
class ScrollDecorator :public Decorator
public:
   ScrollDecorator(Widget* widget)
       :Decorator(widget)
   void show()
       Decorator::show();
       cout<<"ScrollDecorator:show()"<<endl;
int _tmain(int argc, _TCHAR* argv[])
   Widget* twidget = new  TextField(2,3);
   Widget *sd = new ScrollDecorator(twidget);
   Widget *br = new BorderDecorator(twidget);
   sd->show();
   br->show();
   return 0;
