阅读:3577回复:0
Android使用相机照相以及对照片的裁剪
更多 发布于:2012-10-30 10:36
1.Activity源代码:
package com.example.crema;
import java.io.ByteArrayOutputStream;
import java.io.File;
import java.text.SimpleDateFormat;
import java.util.Date;
import android.net.Uri;
import android.os.Bundle;
import android.os.Environment;
import android.provider.MediaStore;
import android.app.Activity;
import android.content.Intent;
import android.graphics.Bitmap;
import android.util.Log;
import android.view.Menu;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.ImageView;
import android.widget.TextView;
public class CramaActivity extends Activity {
    private Button creama=null;
    private ImageView img=null;
    private TextView text=null;
    private File tempFile = new File(Environment.getExternalStorageDirectory(),
            getPhotoFileName());
    private static final int PHOTO_REQUEST_TAKEPHOTO = 1;// 拍照
    private static final int PHOTO_REQUEST_GALLERY = 2;// 从相册中选择
    private static final int PHOTO_REQUEST_CUT = 3;// 结果
   @Override
        setContentView(R.layout.activity_crama);
        init();
        Log.i("TAG-->", ""+Environment.getExternalStorageDirectory());
   private void init() {
        // TODO Auto-generated method stub
    creama=(Button) findViewById(R.id.btn_creama);
    img=(ImageView) findViewById(R.id.img_creama);
    creama.setOnClickListener(listener);
    text=(TextView) findViewById(R.id.text);
    protected void onActivityResult(int requestCode, int resultCode, Intent data) {
        switch (requestCode) {
        case PHOTO_REQUEST_TAKEPHOTO:// 当选择拍照时调用
            startPhotoZoom(Uri.fromFile(tempFile));
            break;
        case PHOTO_REQUEST_GALLERY:// 当选择从本地获取图片时
            // 做非空判断,当我们觉得不满意想重新剪裁的时候便不会报异常,下同
            if (data != null)
                startPhotoZoom(data.getData());
            break;
        case PHOTO_REQUEST_CUT:// 返回的结果
            if (data != null)
                // setPicToView(data);
                sentPicToNext(data);
            break;
        super.onActivityResult(requestCode, resultCode, data);
    private OnClickListener listener=new OnClickListener(){
       @Override
        public void onClick(View arg0) {
            Intent cameraintent = new Intent(MediaStore.ACTION_IMAGE_CAPTURE);
            // 指定调用相机拍照后照片的储存路径
            cameraintent.putExtra(MediaStore.EXTRA_OUTPUT,
            startActivityForResult(cameraintent, PHOTO_REQUEST_TAKEPHOTO);
   @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        getMenuInflater().inflate(R.menu.activity_crama, menu);
        return true;
    private void startPhotoZoom(Uri uri) {
        Intent intent = new Intent("com.android.camera.action.CROP");
        intent.setDataAndType(uri, "image/*");
        // crop为true是设置在开启的intent中设置显示的view可以剪裁
        intent.putExtra("crop", "true");
       // aspectX aspectY 是宽高的比例
        intent.putExtra("aspectX", 1);
        intent.putExtra("aspectY", 1);
       // outputX,outputY 是剪裁图片的宽高
        intent.putExtra("outputX", 300);
        intent.putExtra("outputY", 300);
        intent.putExtra("return-data", true);
        intent.putExtra("noFaceDetection", true);
        startActivityForResult(intent, PHOTO_REQUEST_CUT);
   // 将进行剪裁后的图片传递到下一个界面上
    private void sentPicToNext(Intent picdata) {
        Bundle bundle = picdata.getExtras();
        if (bundle != null) {
            Bitmap photo = bundle.getParcelable("data");
            if (photo==null) {
                img.setImageResource(R.drawable.get_user_photo);
            }else {
                img.setImageBitmap(photo);
//                设置文本内容为    图片绝对路径和名字
                text.setText(tempFile.getAbsolutePath());
            ByteArrayOutputStream baos = null;
            try {
                baos = new ByteArrayOutputStream();
                photo.compress(Bitmap.CompressFormat.JPEG, 100, baos);
                byte[] photodata = baos.toByteArray();
                System.out.println(photodata.toString());
                // Intent intent = new Intent();
                // intent.setClass(RegisterActivity.this, ShowActivity.class);
                // intent.putExtra("photo", photodata);
                // startActivity(intent);
                // finish();
            } catch (Exception e) {
                e.getStackTrace();
            } finally {
                if (baos != null) {
                    try {
                        baos.close();
                        e.printStackTrace();
   // 使用系统当前日期加以调整作为照片的名称
    private String getPhotoFileName() {
        Date date = new Date(System.currentTimeMillis());
        SimpleDateFormat dateFormat = new SimpleDateFormat(
                "'IMG'_yyyyMMdd_HHmmss");
        return dateFormat.format(date) + ".jpg";
2.xml布局文件代码:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent" >
   <Button
        android:id="@+id/btn_creama"
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:layout_centerHorizontal="true"
        android:text="@string/hello_world"
        tools:context=".CramaActivity" />
    <ImageView
        android:id="@+id/img_creama"
        android:layout_width="150dip"
        android:layout_height="150dip"
        android:layout_margin="15dip"
        android:layout_below="@+id/btn_creama"
        android:scaleType="fitXY"
        android:background="@drawable/bg_img_coner"
    <TextView
        android:id="@+id/text"
        android:layout_width="fill_parent"
        android:layout_below="@+id/img_creama"
        android:textSize="16sp"
        android:background="#22000000"
</RelativeLayout>
