阅读:3240回复:0
Phonegap for IOS Plugin插件开发
更多 发布于:2012-10-30 10:37
1.新建Phonegap工程MyPlugin
环境
xcode4.5.1
phonegap2.1.0
2.在Plugin文件夹下创建实现Plugin子类
[plain]
//  MyPlugin.h
//  MyPGPlugin
//  Created by kllmctrl on 12-10-29.
#import <Cordova/CDV.h>
@interface MyPlugin : CDVPlugin
- (void) add:(CDVInvokedUrlCommand*)command;
@end
[plain]
#import "MyPlugin.h"
@implementation MyPlugin
- (void) add:(CDVInvokedUrlCommand*)command{
    CDVPluginResult* pluginResult = nil;
    NSString* javaScript = nil;
    @try {
        NSString* echo = [command.arguments objectAtIndex:0];
        NSString* echo2 = [command.arguments objectAtIndex:1];
        if (echo != nil
            ;; [echo length] > 0
            ;; echo2 != nil
            ;; [echo2 length] > 0) {
             *相加字符串
            NSString *addResult = [NSString stringWithFormat:@"%@%@", echo, echo2];
            pluginResult = [CDVPluginResult resultWithStatus:CDVCommandStatus_OK messageAsString:addResult];
            javaScript = [pluginResult toSuccessCallbackString:command.callbackId];
        } else {
            pluginResult = [CDVPluginResult resultWithStatus:CDVCommandStatus_ERROR];
            javaScript = [pluginResult toErrorCallbackString:command.callbackId];
    } @catch (NSException* exception) {
        pluginResult = [CDVPluginResult resultWithStatus:CDVCommandStatus_JSON_EXCEPTION messageAsString:[exception reason]];
    [self writeJavascript:javaScript];
@end
3.在www->js文件夹下创建实现 MyPlugin.js
[plain]
var MyPlugin = {
add: function(args,args2,addSuc,addFaild) {
    cordova.exec(addSuc, addFaild, "MyPlugin", "add", [args,args2]);
4.修改index.html
[html]
<!DOCTYPE html>
 Licensed to the Apache Software Foundation (ASF) under one
 or more contributor license agreements.  See the NOTICE file
 distributed with this work for additional information
 regarding copyright ownership.  The ASF licenses this file
 to you under the Apache License, Version 2.0 (the
 "License"); you may not use this file except in compliance
 with the License.  You may obtain a copy of the License at
 http://www.apache.org/licenses/LICENSE-2.0
 Unless required by applicable law or agreed to in writing,
 software distributed under the License is distributed on an
 "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
 KIND, either express or implied.  See the License for the
 specific language governing permissions and limitations
 under the License.
<html>
    <head>
        <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
        <meta name="format-detection" content="telephone=no" />
        <meta name="viewport" content="user-scalable=no, initial-scale=1, maximum-scale=1, minimum-scale=1, width=device-width, height=device-height, target-densitydpi=device-dpi" />
        <link rel="stylesheet" type="text/css" href="css/index.css" />
        <title>kllmctrl</title>
    </head>
    <body>
        <div class="app">
            <h1>Apache Cordova kllmctrl</h1>
            <div id="deviceready" class="blink">
                <p class="event listening">Connecting to Device</p>
                <p class="event received">Device is Ready</p>
            </div>
        </div>
        <script type="text/javascript" src="cordova-2.1.0.js"></script>
        <script type="text/javascript" src="js/MyPlugin.js"></script>
        <script type="text/javascript">
        document.addEventListener("deviceready", onDeviceReady, false);
        function onDeviceReady() {
             * 加载成功调用js
            MyPlugin.add("My","Plugin",addSuc,addFiald);
        </script>
             * js回调函数
            function addSuc(result) {
                console.log('addSuc='+result);
            function addFiald() {
                console.log('addFiald');
            </script>
    </body>
</html>
5.配置Cordova.plist
在Plugins建MyPlugin=MyPlugin
6.run
