阅读:3634回复:0
[mysql]MySQL游标语法实例
更多 发布于:2012-10-30 10:50
MySQL游标语法实例
1、基本语法:
Sql代码
#定义游标
declare fetchSeqCursor cursor for select seqname, value from sys_sequence;
#使用游标
open fetchSeqCursor;
#fetch数据
fetch cursor into _seqname, _value;
#关闭游标
close fetchSeqCursor;
 www.atcpu.com
2、单游标例子:
Sql代码
## define the flag for loop judgement
declare fetchSeqOk boolean;
## define the varient for store the data
declare _seqname varchar(50);
declare _value bigint(20);
## define the cursor
## define the continue handler for not found flag
declare continue handler for NOT FOUND set fetchSeqOk = true;
set fetchSeqOk = false;
fetchSeqLoop:Loop
if fetchSeqOk then
leave fetchSeqLoop;
else
select _seqname, _value;
end if;
end Loop;
 www.atcpu.com
3、嵌套的游标循环
java代码
 www.atcpu.com
fetchSeqLoop:Loop
if fetchSeqOk then
leave fetchSeqLoop;
else
#嵌套的游标循环
begin
declare fetchSeqOk boolean default 'inner';
declare cursor2 cursor for select .... from ...;
open cursor2;
fetchloop2 loop
if fetchSeqOk then
else
end if;    www.atcpu.com
end loop;
close cursor2;
end;
#嵌套的游标循环结束
end if;
end Loop;
