public IActionInvoker ActionInvoker {
get {
if (_actionInvoker == null) {
_actionInvoker = CreateActionInvoker();
return _actionInvoker;
set {
_actionInvoker = value;
protected virtual IActionInvoker CreateActionInvoker() {
return new ControllerActionInvoker();
和TempDataProvider属性定义一样,
大家一定要习惯这些代码啊。
而ControllerActionInvoker的定义也很简单,但是这个类却不简单啊。
让我们来看看你InvokeAction的定义吧:
[csharp]
public virtual bool InvokeAction(ControllerContext controllerContext, string actionName) {
if (controllerContext == null) {
throw new ArgumentNullException("controllerContext");
if (String.IsNullOrEmpty(actionName)) {
throw new ArgumentException(MvcResources.Common_NullOrEmpty, "actionName");
ControllerDescriptor controllerDescriptor = GetControllerDescriptor(controllerContext);
ActionDescriptor actionDescriptor = FindAction(controllerContext, controllerDescriptor, actionName);
if (actionDescriptor != null) {
FilterInfo filterInfo = GetFilters(controllerContext, actionDescriptor);
try {
AuthorizationContext authContext = InvokeAuthorizationFilters(controllerContext, filterInfo.AuthorizationFilters, actionDescriptor);
if (authContext.Result != null) {
// the auth filter signaled that we should let it short-circuit the request
InvokeActionResult(controllerContext, authContext.Result);
else {
if (controllerContext.Controller.ValidateRequest) {
ValidateRequest(controllerContext);
IDictionary<string, object> parameters = GetParameterValues(controllerContext, actionDescriptor);
ActionExecutedContext postActionContext = InvokeActionMethodWithFilters(controllerContext, filterInfo.ActionFilters, actionDescriptor, parameters);
InvokeActionResultWithFilters(controllerContext, filterInfo.ResultFilters, postActionContext.Result);
catch (ThreadAbortException) {
// This type of exception occurs as a result of Response.Redirect(), but we special-case so that
// the filters don't see this as an error.
throw;
catch (Exception ex) {
// something blew up, so execute the exception filters
ExceptionContext exceptionContext = InvokeExceptionFilters(controllerContext, filterInfo.ExceptionFilters, ex);
if (!exceptionContext.ExceptionHandled) {
throw;
InvokeActionResult(controllerContext, exceptionContext.Result);
return true;
// notify controller that no method matched
return false;
try {
else {
throw;
throw;
return true;
return false;
}这个方法里面的内容不可能一次讲完的,我们看看 ControllerDescriptor controllerDescriptor = GetControllerDescriptor(controllerContext);很明显ControllerDescriptor是Controller实例的一个包装类。 protected virtual ControllerDescriptor GetControllerDescriptor(ControllerContext controllerContext) {
Type controllerType = controllerContext.Controller.GetType();
ControllerDescriptor controllerDescriptor = DescriptorCache.GetDescriptor(controllerType, () => new ReflectedControllerDescriptor(controllerType));
return controllerDescriptor;
从这个方法中,我们可以知道实际返回的是一个ReflectedControllerDescriptor实例,它是ControllerDescriptor的子类,DescriptorCache.GetDescriptor(...)好像是从缓存中获取的啊,让我们证实一下吧,先来看看ControllerDescriptorCache的GetDescriptor方法:
internal sealed class ControllerDescriptorCache : ReaderWriterCache<Type, ControllerDescriptor> {
public ControllerDescriptor GetDescriptor(Type controllerType, Func<ControllerDescriptor> creator) {
return FetchOrCreateItem(controllerType, creator);
FetchOrCreateItem方法很简单,从缓存中获取ControllerDescriptor ,如果没有就创建并加入缓存然后在返回,缓存实现方式其实就是一个字典Dictionary<TKey, TValue>。
现在看看ReflectedControllerDescriptor的够着函数是否有什么特别之处:
_controllerType = controllerType;
_selector = new ActionMethodSelector(_controllerType);
怎么又有ActionMethodSelector这个东东啊,其构造函数如下
public ActionMethodSelector(Type controllerType) {
ControllerType = controllerType;
PopulateLookupTables();
private void PopulateLookupTables() {
MethodInfo[] allMethods = ControllerType.GetMethods(BindingFlags.InvokeMethod | BindingFlags.Instance | BindingFlags.Public);
MethodInfo[] actionMethods = Array.FindAll(allMethods, IsValidActionMethod);
AliasedMethods = Array.FindAll(actionMethods, IsMethodDecoratedWithAliasingAttribute);
NonAliasedMethods = actionMethods.Except(AliasedMethods).ToLookup(method => method.Name, StringComparer.OrdinalIgnoreCase);
这个方法很简单,找出ControllerType的所有实例、共有方法,然后在过滤调不是Action的,最后吧这些Action方法分成两部分,一部分有别名,一部分没有别名。
现在我们已经得到了ControllerDescriptor实例,下面应该来看看ActionDescriptor actionDescriptor = FindAction(controllerContext, controllerDescriptor, actionName);这句代码了;同样我们可以确认ActionDescriptor实际上一个Action的包装类。
protected virtual ActionDescriptor FindAction(ControllerContext controllerContext, ControllerDescriptor controllerDescriptor, string actionName)这个方法实际上就是调用
ControllerDescriptor类FindAction方法,让我们看看你ReflectedControllerDescriptor的FindAction方法,该方法很简单,组要就2句代码:
MethodInfo matched = _selector.FindActionMethod(controllerContext, actionName);
return new ReflectedActionDescriptor(matched, actionName, this);
_selector.FindActionMethod(controllerContext, actionName);这句就是找到我们需要Action对应的MethodInfo。
[csharp]
public MethodInfo FindActionMethod(ControllerContext controllerContext, string actionName) {
List<MethodInfo> methodsMatchingName = GetMatchingAliasedMethods(controllerContext, actionName);
methodsMatchingName.AddRange(NonAliasedMethods[actionName]);
List<MethodInfo> finalMethods = RunSelectionFilters(controllerContext, methodsMatchingName);
switch (finalMethods.Count) {
case 0:
return null;
case 1:
return finalMethods[0];
default:
throw CreateAmbiguousMatchException(finalMethods, actionName);
case 0:
return null;
case 1:
default:
默认情况下,我们的Action是没有别名的 List<MethodInfo> methodsMatchingName = GetMatchingAliasedMethods(controllerContext, actionName);这句执行后是没有什么结果的,而RunSelectionFilters的实现比较特别
[csharp]
private static List<MethodInfo> RunSelectionFilters(ControllerContext controllerContext, List<MethodInfo> methodInfos) {
// remove all methods which are opting out of this request
// to opt out, at least one attribute defined on the method must return false
List<MethodInfo> matchesWithSelectionAttributes = new List<MethodInfo>();
List<MethodInfo> matchesWithoutSelectionAttributes = new List<MethodInfo>();
foreach (MethodInfo methodInfo in methodInfos) {
ICollection<ActionMethodSelectorAttribute> attrs = ReflectedAttributeCache.GetActionMethodSelectorAttributes(methodInfo);
if (attrs.Count == 0) {
matchesWithoutSelectionAttributes.Add(methodInfo);
else if (attrs.All(attr => attr.IsValidForRequest(controllerContext, methodInfo))) {
matchesWithSelectionAttributes.Add(methodInfo);
// if a matching action method had a selection attribute, consider it more specific than a matching action method
// without a selection attribute
return (matchesWithSelectionAttributes.Count > 0) ? matchesWithSelectionAttributes : matchesWithoutSelectionAttributes;
循环每个MethodInfo,查找它们的自定义的ActionMethodSelectorAttribute特性,如果有只返回验证通过的特性。看到ReflectedAttributeCache.GetActionMethodSelectorAttributes(methodInfo)这样的代码感觉由于缓存有关,
private static ReadOnlyCollection<TAttribute> GetAttributes<TMemberInfo, TAttribute>(ConcurrentDictionary<TMemberInfo, ReadOnlyCollection<TAttribute>> lookup, TMemberInfo memberInfo)
where TAttribute : Attribute
where TMemberInfo : MemberInfo {
return lookup.GetOrAdd(memberInfo, mi => new ReadOnlyCollection<TAttribute>((TAttribute[])memberInfo.GetCustomAttributes(typeof(TAttribute), inherit: true)));
ReflectedAttributeCache这个类有几个缓存字典:
ConcurrentDictionary<MethodInfo, ReadOnlyCollection<ActionMethodSelectorAttribute>>
ConcurrentDictionary<MethodInfo, ReadOnlyCollection<ActionNameSelectorAttribute>>
ConcurrentDictionary<MethodInfo, ReadOnlyCollection<FilterAttribute>>
ConcurrentDictionary<Type, ReadOnlyCollection<FilterAttribute>>
默认实现ActionMethodSelectorAttribute类主要有以下几个
AcceptVerbsAttribute
HttpDeleteAttribute
HttpGetAttribute
HttpPostAttribute
HttpPutAttribute
NonActionAttribute
剩下的就是直接实例一个ReflectedActionDescriptor对象了,这个也没什么特殊,只是里面有一个验证方法
if (validateMethod) {
string failedMessage = VerifyActionMethodIsCallable(methodInfo);
if (failedMessage != null) {
throw new ArgumentException(failedMessage, "methodInfo");
用来验证该方法是否可以执行,以下几种情况经不会通过,(1)方法是静态方法(2)方法的实例类型不是ControllerBase(3)是否包含泛型参数如 public ActionResult Index<T>()是非法的,但 public ActionResult Index(List<string> aa)是合法(4)参数中不能含有Ref和out。
这篇文章说的很散,我们需要注意一点
微软在mvc里面缓存做的很好了,在前面个将获取ControllerTyper时它是有缓存的,一次读取当前程序集所有的ControllerType,在这里提到了一个DescriptorCache 缓存每次调用的ControllerType->ReflectedControllerDescriptor,而ReflectedControllerDescriptor实例会一次去读该Controller的所有Action方法;这里还有一个ReflectedAttributeCache,缓存每次调用MethodInfo的所有特性(ActionMethodSelectorAttribute、ActionNameSelectorAttribute、FilterAttribute),当然FilterAttribute特性还可以在类上面。
