阅读:3464回复:0
[SQL Server]Entity SQL使用技巧
更多 发布于:2012-12-13 15:08
Entity SQL使用技巧
1.由Entity SQL获得标准SQL语句
 www.atcpu.com
Entity to Linq:
string sql=(this.ObjectContext.IrrLRoles.Where(d => d.rname.StartsWith("a")) as ObjectQuery).ToTraceString();
标准SQL:
SELECT
[Extent1].[rid] AS [rid],
[Extent1].[rname] AS [rname],
[Extent1].[state] AS [state],
[Extent1].[sysfuns] AS [sysfuns]
FROM [dbo].[IrrLRoles] AS [Extent1]
WHERE [Extent1].[rname] LIKE 'a%'
2.在Entity SQL中执行查询语句:  www.atcpu.com
string ids = "1,2,3,4,5,6,7,8";
return this.ObjectContext.ExecuteStoreQuery<IrrlSysFun>("select * from IrrlSysFun as s where s.nodeid in ("+ids+")").AsQueryable();
通过ExecuteStoreQuery方法执行!
