阅读:3087回复:0
Android自定义Toast
更多 发布于:2013-01-10 15:39
mainActivity如下:
[java]
package cn.c;
import android.app.Activity;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.Toast;
//自定义Toast
public class MainActivity extends Activity {
    private Button mButton;
    @Override
        mButton=(Button) findViewById(R.id.button);
        mButton.setOnClickListener(new ClickListenerImpl());
    private class ClickListenerImpl implements OnClickListener{
        public void onClick(View v) {
            Toast toast=Toast.makeText(MainActivity.this, "", Toast.LENGTH_SHORT);
            View toastView=
            LayoutInflater.from(MainActivity.this).inflate(R.layout.toast, null);
            toast.setView(toastView);
            toast.show();
main.xml如下:
[html]
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent" >
   <Button
       android:id="@+id/button"
       android:layout_width="150dip"
       android:layout_height="50dip"
       android:text="弹出Toast"
       android:layout_alignParentTop="true"
       android:layout_centerHorizontal="true"
</RelativeLayout>
toast.xml如下:
[html]
<LinearLayout
    android:layout_width="wrap_content"
    android:orientation="horizontal" >
    <ImageView
       android:id="@+id/imageView"
       android:layout_width="50dip"
       android:layout_height="40dip"
       android:src="@drawable/ic_launcher"
    <TextView
       android:id="@+id/textView"
       android:text="自定义的Toast"
       android:gravity="center"
</LinearLayout>
