阅读:3241回复:0
[Android Trick 3]获取网络状态并进入设置
更多 发布于:2013-01-10 15:43
关键字:网络状态,系统设置,系统时间,时间格式化
首先是判断系统的网络状态
 www.atcpu.com
* 对网络连接状态进行判断
* @return true, 可用; false, 不可用
private boolean isOpenNetwork() {
    ConnectivityManager connManager = (ConnectivityManager) getSystemService(Context.CONNECTIVITY_SERVICE);
    if (connManager.getActiveNetworkInfo() != null) {
        return connManager.getActiveNetworkInfo().isAvailable();
    return false;
PS:你肯定要加入网络访问的权限
[html]
<uses-permission android:name="android.permission.interNET"></uses-permission>
    <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
如果没有网络则进入设置界面
[java]
if (isOpenNetwork() == true) {
} else {
    AlertDialog.Builder builder = new AlertDialog.Builder(
                    SomeActivity.this);
    builder.setTitle("title")
            .setMessage("message");
    builder.setPositiveButton(resources.getString(R.string.ok),
        new DialogInterface.OnClickListener() {
        @Override
        public void onClick(DialogInterface dialog, int which) {
        <span style="white-space:pre">  </span>Intent intent = null;
            try {
                String sdkVersion = android.os.Build.VERSION.SDK;
                if (Integer.valueOf(sdkVersion) > 10) {
                    intent = new Intent(
                    android.provider.Settings.ACTION_SETTINGS);
                } else {
                    intent = new Intent();
                    ComponentName comp = new ComponentName(
                        "com.android.settings",
                        "com.android.settings.Settings");
                    intent.setComponent(comp);
                    intent.setAction("android.intent.action.VIEW");
                    SomeActivity.this.startActivity(intent);
            } catch (Exception e) {
                Log.v("LOG","open network settings failed, please check...");
            <span style="white-space:pre">  </span>e.printStackTrace();
            <span style="white-space:pre">  </span>}
        .setNegativeButton(resources.getString(R.string.no),
            @Override
            public void onClick(DialogInterface dialog,int which) {
                dialog.cancel();
                finish();
        }).show();
这里再引申一下,通过android.provider.Settings可以获取很多我们需要的和系统设置相关的信息,比如系统时间是24还是12制
[java]
ContentResolver cv = this.getContentResolver();
       String strTimeFormat = android.provider.Settings.System.getString(cv,
                                          android.provider.Settings.System.TIME_12_24);
       if(strTimeFormat.equals("24"))
              Log.i("activity","24");
额。。这篇博客写得比较杂,那就把时间格式化,获取系统时间也补上吧
[java]
SimpleDateFormat sdf=new SimpleDateFormat("yyyy-MM");  //参数为你想要显示的时间格式
String date=sdf.format(new java.util.Date());
利用Calendar获取
[java]
Calendar c = Calendar.getInstance();
取得系统日期:year = c.get(Calendar.YEAR)
               month = c.grt(Calendar.MONTH)
               day = c.get(Calendar.DAY_OF_MONTH)
取得系统时间:hour = c.get(Calendar.HOUR_OF_DAY);
                  minute = c.get(Calendar.MINUTE)
利用Time获取
[java]
Time t=new Time(); // or Time t=new Time("GMT+8"); 加上Time Zone资料。
t.setToNow(); // 取得系统时间。
int year = t.year;
int month = t.month;
int date = t.monthDay;
int hour = t.hour; // 0-23
int minute = t.minute;
int second = t.second;
