阅读:2775回复:0
为网站添加安全机制,windows与Form验证
更多 发布于:2013-01-13 00:33
--------web.config-------------- <!--基于Windows的身份认证-->
<configuration>
<system.web>
<authentication mode="Windows"></authentication>
<authorization>
<!--除了匿名之外别人都可以-->
<deny users="?"/>
<allow users="*"/>
<!-- 授权,除了Test这个匿名,别人都可以-->
<deny users="?"/>
<deny users="Test"/>
<allow users="*"/>
</authorization>
<compilation debug="true" targetFramework="4.0" />
</system.web>
</configuration>
<!--基于Froms的身份认证-->
<configuration>
<system.web>
<authentication mode="Forms">
<!--loginUrl登录时的那个页面(所有的用户都从登录这个页面进入网站,别的地方不让进)
给Cookie加密protection -->
<forms loginUrl="login.aspx" timeout="2880" name="aaa" protection="Encryption"/>
</authentication>
<!--授权-->
<authorization>
<deny users="?"/>
<allow users="*"/>
</authorization>
</system.web>
<!--在images文件夹下的图片是可以被访问的-->
<location path="images">
<system.web>
<authorization>
<allow users="?"/>
</authorization>
</system.web>
</location>
<!--在subPages文件夹下的子页是可以被访问的-->
<location path="subpages">
<system.web>
<authorization>
<allow users="?"/>
</authorization>
</system.web>
</location>
</configuration>
----------registor.aspx-----------
<body>
<form id="form1" runat="server">
<div>
注册页……
</div>
</form>
</body>
-----------default1.aspx------------
<body>
<div>
default1页………………
</div>
</form>
</body>
---------------Login.aspx--------------------
<body>
<div>
<asp:TextBox ID="TextBox1" runat="server"></asp:TextBox>
<asp:TextBox ID="TextBox2" runat="server"></asp:TextBox>
<asp:Button ID="Button1" runat="server" Text="Button" Xonclick="Button1_Click" />
<br />
<br />
<img src="images/1.gif" />
www.atcpu.com
<br />
<asp:Login ID="LoginControl" runat="server">
</asp:Login>
</div>
</form>
</body>
--------------Login.aspx.cs-----------------------
protected void Button1_Click(object sender, EventArgs e)
if (this.TextBox1.Text == "admin" ;; this.TextBox2.Text == "123")
//from授权,
FormsAuthentication.SetAuthCookie(this.TextBox1.Text, false);
