111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:4497回复:0
一个oracle分页程式,挺实用的._php实例
更多 发布于:2010-12-15 13:28
// How to split the result into pages, like limits in MySQL?
// Tutorial by Neil Craig (neilc@netactive.co.za)
// Date: 2001-06-05
// With this example, I will explain paging of database queries where the
// result is more than the developer want to print to the page, but wish to
// split the result into seperate pages.
// The table "SAMPLE_TABLE" accessed in this tutorial has 4 fields:
// PK_ID, FIELD1, FIELD2 and FIELD3. The types dont matter but you should
// define a primary key on the PK_ID field.
$display_rows = 5;     // The rows that should be display at a time. You can
                       // modify this if you like.
// Connect to the Oracle database
putenv("ORACLE_SID=purk");
putenv("ORACLE_HOME=/export/oracle8i");
putenv("TNS_ADMIN=$ORACLE_HOME/network/admin");
$OracleDBConn = OCILogon("purk","purk","lengana.world");
// This query counts the records
$sql_count = "SELECT COUNT(*) FROM SAMPLE_TABLE";
// Parse the SQL string ; execute it
$row_count=OCIParse($OracleDBConn, $sql_count);
OCIExecute($row_count);
// From the parsed ; executed query, we get the amount of records found.
// Im not storing this result into a session variable because it allows for
// new records to be shown as it is entered by another user while the result
// is printed.
if (OCIFetch($row_count)) {
    $num_rows = OCIResult($row_count,1);
} else {
    $num_rows = 0;        // If no record was found
// Free the resources that were used for this query
OCIFreeStatement($row_count);
// We need to prepare the query that will print the results as a page. I will
// explain the query to you in detail.
// If no page was specified in the url (ex. http://mysite.com/result.php?page=2),
// set it to page 1.
if (empty($page) || $page == 0) {
    $page = 1;
// The start range from where the results should be printed
$start_range = (($page - 1) * $display_rows) + 1;
// The end range to where the results should be printed
$end_range = $page * $display_rows;
// The main query. It consists of 3 "SELECT" statements nested into each
// other. The center query is the query you would normally use to return the
// records you want. Do you ordering and "WHERE" clauses in this statement.
// We select the rows to limit our results but because the row numbers are
// assigned to the rows before any ordering is done, lets the code print the
// result unsorted.
// The second nested "SELECTED" assigns the new row numbers to the result
// for us to select from.
$sql = "SELECT PK_ID, FIELD1, FIELD2, FIELD3, ROW_NO FROM (SELECT PK_ID, ";
$sql .= "FIELD1, FIELD2, FIELD3, ROWNUM ROW_NO FROM (SELECT PK_ID, FIELD1, ";
$sql .= "FIELD2, FIELD3 FROM SAMPLE_TABLE ORDER BY FIELD3)) WHERE ROW_NO BETWEEN ";
$sql .= $start_range." AND ".$end_range;
// start results formatting
echo "
echo "
if ($num_rows != 0) {
    $rs=OCIParse($OracleDBConn, $sql);
    OCIExecute($rs);
    // get number of columns for use later
    $num_columns = OCINumCols($rs);
    while (OCIFetch($rs)){
        echo "
} else {
    // Print a message stating that no records was found
    echo "
// Close the table
echo "
echo "
[td]PK ID[/td]";
echo "
[td]Field 1[/td]";
echo "
[td]Field 2[/td]";
echo "
[td]Field 3[/td]";
echo "
[td]Row No[/td]";
echo "
        for ($i = 1; $i < ($num_columns + 1); $i++) {
            $column_value = OCIResult($rs,$i);
            echo "
[td]$column_value[/td]";
        echo "
Sorry! No records was found
// free resources and close connection
OCIFreeStatement($rs);
OCILogoff($OracleDBConn);
<?php
// Here we will print the links to the other pages
// Calculating the amount of pages
if ($num_rows % $display_rows == 0) {
    $total_pages = $num_rows / $display_rows;
} else {
    $total_pages = ($num_rows / $display_rows) + 1;
    settype($total_pages, integer); // Rounding the variable
// If this is not the first page print a link to the previous page
if ($page != 1) {
    echo "
Previous";
// Now we can print the links to the other pages
for ($i = 1; $i <= $total_pages;  $i++) {
    if ($page == $i){
        // Dont print the link to the current page
        echo " ".$i;
    } else {
        //Print the links to the other pages
        echo "
".$i."";
// If this is not the last page print a link to the next page
if ($page < $total_pages) {
    echo "
Next";
<?php
// Im just adding this section to print some of the variables for extra info
// and some debugging
echo "
Total pages: ".$total_pages."
echo "
Number of records: ".$num_rows."
echo "
The SQL Query is: ".$sql."
