阅读:2140回复:0
ImageCMS 4.0.0b多重缺陷及修复
更多 发布于:2013-01-29 13:54
影响产品: ImageCMS
开发者: www.imagecms.net
影响版本:4.0.0b 及以前Tested Version: 4.0.0b
缺陷类型: SQL Injection [CWE-89]
状态: 官方已修复
Discovered and Provided: High-Tech Bridge Security Research Lab ( https://www.htbridge.com/advisory/ )
 High-Tech Bridge Security Research Lab discovered vulnerability in ImageCMS, which can be exploited to perform SQL injection attacks.
 1)  SQL injection vulnerability in ImageCMS: CVE-2012-6290
The vulnerability exists due to insufficient filtration of the "q" HTTP GET parameter passed to "/admin/admin_search/". A remote authenticated administrator can execute arbitrary SQL commands in the application's database.
Depending on the database and system configuration PoC (Proof-of-Concept) code below will create "/tmp/file.txt" file with MySQL server version inside:
 http://www.atcpu.copm/admin/admin_search?q=123%27%20UNION%20SELECT%201,2,version%28%29,4,5,6,7,8,9,10,11,1 2,13,14,15%20INTO%20OUTFILE%27/tmp/file.txt%27%20--%202
This vulnerability can also be exploited by remote non-authenticated attacker via CSRF vector because the application is prone to Cross-Site Request Forgery attack. In order to do so attacker should trick a logged-in administrator to visit a web page with CSRF exploit.
Basic CSRF exploit 示例
<img src="http://[host]/admin/admin_search?q=123%27%20UNION%20SELECT%201,2,version%28%29,4,5,6,7,8,9,10,11,1 2,13,14,15%20INTO%20OUTFILE%27/tmp/file.txt%27%20--%202">
 解决方案:
 升级至 ImageCMS 4.2
More Information:
http://forum.imagecms.net/viewtopic.php?id=1436
http://www.imagecms.net/blog/news/reliz-imagecms-42-razgranichenie-prav-dostupa-i-drugie-novinki
