阅读:10558回复:0
android预置频道有时失败情况如何处理?
更多 发布于:2013-05-12 13:02
a.添加一个全局变量
private int retryNum = 5;
b.
SmsReadyBroadcastReceiver的 onReceive方法里,多加一条trace,将simId打印出来,如下:
int extra =
intent.getIntExtra("simId",0);
Log.e("kpp","extra="+extra);
c.handleSetStateResponse方法
如果发生exception则重试,在if
(ar.exception != null)语句里添加实现体,如下:
 if (ar.exception != null)
            if(retryNum >
0){
             Message
msg;
             retryNum --;
Log.e("kpp","retryNum="+retryNum);
Log.e("kpp","simId="+simId);
              msg =
mHandler.obtainMessage(MESSAGE_SET_STATE, simId,
MESSAGE_SET_STATE,null);
if (FeatureOption.MTK_GEMINI_SUPPORT == true)
((Geminiphone)phone).activateCellBroadcastSmsGemini(0,msg, simId);
else
            phone.activateCellBroadcastSms(0,msg);
return;
else{
   if(DBG)
Log.d(LOG_TAG, "handleSetStateResponse: ar.exception="+ ar.exception);
