阅读:3165回复:0
[C++技术]C++实现Huffman最优二叉树
更多 发布于:2013-05-13 10:07
Huffman最优二叉树对于压缩编码具有重要作用
本文利用C++实现了Huffman二叉树做学习参考
[cpp]
/*huffman树——最优二叉树*/
#include <iostream>
#include <vector>
#include <algorithm>
using namespace std;
//定义节点结构体类型
typedef struct Node {
    int val;
    Node *left, *right, *parent;  //左右节点和父节点指针
    void set(int value, Node *lft, Node *rgt) {
        val = value;
        left = lft;
        right = rgt;
        parent = NULL;
    Node() {
        val = -1;
        left = right = parent = NULL;
} Node;
//存放节点的向量
vector<Node> nodes;
//存放节点编号的向量
vector<int> pnodes;
//初始化最小带权路径和
int sum = 0;
//按照节点编号对应节点的值对编号进行排序
bool sortpnode(int a, int b)
    return nodes[a].val < nodes.val;
//利用递归遍历huffman树实现输出
void output(Node *tree)
    Node *ptr;
    //若当前节点为空,退出
    if (tree == NULL)
        return;
    //否则,输出当前根节点的值
    cout << tree->val << "-> Left: " << (tree->left ? tree->left->val : -1) << ", Right: " << (tree->right ? tree->right->val : -1) << endl;
    //若左孩子不为空,则通过递归遍历左子树
    if (tree->left)
        output(tree->left);
    //若左孩子已遍历,且右子树不为空,则通过递归遍历右子树
    if (tree->right)
        output(tree->right);
    //若当前节点的左右孩子都为空,则说明该节点是叶子节点
    //此时,计算其带权路径并求和
    if (!tree->left && !tree->right)
        //计算到根节点的长度
        int level = 0;
        ptr = tree->parent;
        while(ptr != NULL)
            level++;
            ptr = ptr->parent;
        //用叶子深度乘以
        sum += level * tree->val;
        cout << "深度:" << level << ", 节点值:" << tree->val << ",带权路径和=" << sum << endl;
int main()
    int values[] = {1, 2, 3, 4, 5, 30, 5, 8},
        n = sizeof(values)/sizeof(int);
    int cnt = n;
    Node *tnode;
    //直接在nodes中放入(2 + n) * n / 2
    nodes.resize(2 * n - 1);
    //为pnodes设置n个元素,且每个元素——即节点编号为-1
    pnodes.resize(n, -1);
    //为节点赋值
    for(int i = 0; i < n; i++)
        nodes.val = values;
        pnodes = i;
    //循环
    while(pnodes.size() > 1)
        //按照节点编号所对象节点的值对节点编号排序
        sort(pnodes.begin(), pnodes.end(), sortpnode);
        //0--n-1为已处理节点,cnt编号对应的为待处理节点
        tnode = &nodes[cnt];
        //为派生节点赋值并指定左、右孩子及父节点
        tnode->val = nodes[pnodes[0]].val + nodes[pnodes[1]].val;
        tnode->left = &nodes[pnodes[0]];
        tnode->right = &nodes[pnodes[1]];
        tnode->parent = NULL;
        //将派生节点编号加入pnodes向量
        pnodes.insert(pnodes.begin(), cnt);
        //设置孩子节点的父节点地址
        nodes[pnodes[1]].parent = &nodes[cnt];
        nodes[pnodes[2]].parent = &nodes[cnt];
        //从pnodes中删除已处理的节点编号
        pnodes.erase(pnodes.begin() + 1);
        //设置下一个派生节点的编号
        cnt++;
    //nodes[cnt-1]为树的根节点
    //输出树
    output(&nodes[cnt-1]);
    //输出huffman树的最小带权路径长度
    cout << "最小带权路径长为:" << sum << endl;
    return 0;
/*huffman树——最优二叉树*/
#include <iostream>
#include <vector>
//定义节点结构体类型
 int val;
  val = value;
  left = lft;
  right = rgt;
  parent = NULL;
 Node() {
  val = -1;
} Node;
//存放节点的向量
vector<Node> nodes;
//存放节点编号的向量
vector<int> pnodes;
//初始化最小带权路径和
int sum = 0;
 Node *ptr;
 //若当前节点为空,退出
 if (tree == NULL)
  return;
 //否则,输出当前根节点的值
 if (tree->left)
  output(tree->left);
 if (tree->right)
 //此时,计算其带权路径并求和
  //计算到根节点的长度
  int level = 0;
  ptr = tree->parent;
  while(ptr != NULL)
   level++;
   ptr = ptr->parent;
  //用叶子深度乘以
int main()
 int cnt = n;
 Node *tnode;
 //为节点赋值
  nodes.val = values;
  pnodes = i;
 //循环
  //将派生节点编号加入pnodes向量
  //设置孩子节点的父节点地址
  //设置下一个派生节点的编号
  cnt++;
 //输出树
 return 0;
