阅读:2602回复:0
[编程工具]TurboC++ for Windows 7 3.7.99
更多 发布于:2013-05-25 14:13
TurboC+ + Windows 7 是为您提供安装和更新小版本的 Windows 上运行TurboC + + IDE 的简单方法创建的方便工具
TurboC+ +环境部署在 DOS
TurboC++ for Windows is a modified version of the Borland Turbo C++ that can be run on newer versions of Windows, such as Vista, 7 and 8. The application sports all the features of the old IDE, eliminating all the incompatibility issues that are encountered in a normal Turbo C++ installation on modern Windows editions.仿真程序内部,您将能够享受这种编程语言的所有功能。
