阅读:2000回复:0
regini dos下更改注册表权限的工具
更多 发布于:2013-06-03 11:30
regini 可是一个好用强大的工具!我仔细查阅了 微软的资料 发现说的含糊不清 google了下也是 寥寥几笔 。
这个玩意主要用途是 在cmd下 修改注册表 以及 注册表权限!
用法研究了一晚上 弄出来了 ,微软上写的 根本不能用啊 郁闷。。
使用方法
C:\>regini regset.ini 就行啦
regset.ini 是你要修改的数据 下面举例!
regset.ini 文件内容
引用:
复制代码 代码如下:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
test = c:\windows\system32\fucktheworld.exe
就是在启动项加个键值 test 内容是启动 c:\windows\system32\fucktheworld.exe
很简单吧!
引用:
复制代码 代码如下:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [17]
把run项设为只允许system控制 其他用户不可控制 [17] 为控制参数 其他参数看下面的帮助
复制代码 代码如下:
L:hacker>regini
usage: REGINI [-m machinename | -h hivefile hiveroot | -w Win95 Directory]
[-i n] [-o outputWidth]
[-b] textFiles...
where: -m specifies a remote windows NT machine whose registry is to be manipula
ted.
-h specifies a specify local hive to manipulate.
-w specifies the paths to a windows 95 system.dat and user.dat files
-i n specifies the display indentation multiple. Default is 4
-o outputWidth specifies how wide the output is to be. By default the
outputWidth is set to the width of the console window if standard
output has not been redirected to a file. In the latter case, an
outputWidth of 240 is used.
-b specifies that REGINI should be backward compatible with older
versions of REGINI that did not strictly enforce line continuations
and quoted strings Specifically, REG_BINARY, REG_RESOURCE_LIST and
REG_RESOURCE_REQUIREMENTS_LIST data types did not need line
continuations after the first number that gave the size of the data.
It just kept looking on following lines until it found enough data
values to equal the data length or hit invalid input. Quoted
strings were only allowed in REG_MULTI_SZ. They could not be
specified around key or value names, or around values for REG_SZ or
REG_EXPAND_SZ Finally, the old REGINI did not support the semicolon
as an end of line comment character.
textFiles is one or more ANSI or Unicode text files with registry data.
The easiest way to understand the format of the input textFile is to use
the REGDMP command with no arguments to dump the current contents of
your NT Registry to standard out. Redirect standard out to a file and
this file is acceptable as input to REGINI
Some general rules are:
Semicolon character is an end-of-line comment character, provided it
is the first non-blank character on a line
Backslash character is a line continuation character. All
characters from the backslash up to but not including the first
non-blank character of the next line are ignored. If there is more
than one space before the line continuation character, it is
replaced by a single space.
Indentation is used to indicate the tree structure of registry keys
The REGDMP program uses indentation in multiples of 4. You may use
hard tab characters for indentation, but embedded hard tab
characters are converted to a single space regardless of their
position
Values should come before child keys, as they are associated with
the previous key at or above the value's indentation level.
For key names, leading and trailing space characters are ignored and
not included in the key name, unless the key name is surrounded by
quotes. Imbedded spaces are part of a key name.
Key names can be followed by an Access Control List (ACL) which is a
series of decimal numbers, separated by spaces, bracketed by a
square brackets (e.g. [8 4 17]). The valid numbers and their
meanings are:
1 - Administrators Full Access
2 - Administrators Read Access
3 - Administrators Read and Write Access
4 - Administrators Read, Write and Delete Access
5 - Creator Full Access
6 - Creator Read and Write Access
7 - World Full Access
8 - World Read Access
9 - World Read and Write Access
10 - World Read, Write and Delete Access
11 - Power Users Full Access
12 - Power Users Read and Write Access
13 - Power Users Read, Write and Delete Access
14 - System Operators Full Access
15 - System Operators Read and Write Access
16 - System Operators Read, Write and Delete Access
17 - System Full Access
18 - System Read and Write Access
19 - System Read Access
20 - Administrators Read, Write and Execute Access
21 - interactive User Full Access
22 - Interactive User Read and Write Access
23 - Interactive User Read, Write and Delete Access
If there is an equal sign on the same line as a left square bracket
then the equal sign takes precedence, and the line is treated as a
registry value. If the text between the square brackets is the
string DELETE with no spaces, then REGINI will delete the key and
any values and keys under it.
For registry values, the syntax is:
value Name = type data
Leading spaces, spaces on either side of the equal sign and spaces
between the type keyword and data are ignored, unless the value name
is surrounded by quotes. If the text to the right of the equal sign
is the string DELETE, then REGINI will delete the value.
The value name may be left off or be specified by an at-sign
character which is the same thing, namely the empty value name. So
the following two lines are identical:
= type data
@ = type data
This syntax means that you can't create a value with leading or
trailing spaces, an equal sign or an at-sign in the value name,
unless you put the name in quotes.
Valid value types and format of data that follows are:
REG_SZ text
REG_EXPAND_SZ text
REG_MULTI_SZ "string1" "str""ing2" ...
REG_DATE mm/dd/yyyy HH:MM DayOfWeek
REG_DWORD numberDWORD
REG_BINARY numberOfBytes numberDWORD(s)...
REG_NONE (same format as REG_BINARY)
REG_RESOURCE_LIST (same format as REG_BINARY)
REG_RESOURCE_REQUIREMENTS (same format as REG_BINARY)
REG_RESOURCE_REQUIREMENTS_LIST (same format as REG_BINARY)
REG_FULL_RESOURCE_DESCRIPTOR (same format as REG_BINARY)
REG_QWORD numberQWORD
REG_MULTISZ_FILE fileName
REG_BINARYFILE fileName
If no value type is specified, default is REG_SZ
For REG_SZ and REG_EXPAND_SZ, if you want leading or trailing spaces
in the value text, surround the text with quotes. The value text
can contain any number of imbedded quotes, and REGINI will ignore
them, as it only looks at the first and last character for quote
characters.
For REG_MULTI_SZ, each component string is surrounded by quotes. If
you want an imbedded quote character, then double quote it, as in
string2 above.
For REG_BINARY, the value data consists of one or more numbers The
default base for numbers is decimal. Hexidecimal may be specified
by using 0x prefix. The first number is the number of data bytes,
excluding the first number. After the first number must come enough
numbers to fill the value. Each number represents one DWORD or 4
bytes. So if the first number was 0x5 you would need two more
numbers after that to fill the 5 bytes. The high order 3 bytes
of the second DWORD would be ignored.
Whenever specifying a registry path, either on the command line
or in an input file, the following prefix strings can be used:
HKEY_LOCAL_MACHINE
HKEY_USERS
HKEY_CURRENT_USER
USER:
Each of these strings can stand alone as the key name or be followed
a backslash and a subkey path.
REGINI: No textFile specified
下面是这个代码的下载 regini.rar
