阅读:2279回复:0
九九乘法表 批处理版
更多 发布于:2013-06-05 10:52
@echo off
:: 九九乘法表
set num=0
for /l %%i in (1,1,9) do (
for /l %%j in (1,1,%%i) do call :multiply %%i %%j
pause>nul
goto :eof
:multiply
set /a num+=1
set /a var=%1*%2
set var=%2×%1=%var%
set var=%var%
if %2 equ 1 (set var=%var:~0,5%) else set var=%var:~0,6%
set str=%str% %var%
if %num% equ %1 echo %str%&set str=&set num=0
goto :eof
:: 另外一种,用Tab键替代空格键来排版
@ECHO %DBG% OFF
SETLOCAL ENABLEDELAYEDEXPANSION
for /l %%j in (1,1,%%i) do (
set /a h=%%i*%%j
set /p=%%i×%%j^=!h! if %%i==%%j echo.
pause
@echo off
:: 99 乘法表
setlocal enabledelayedexpansion
for /l %%a in (1,1,9) do (
for /l %%b in (1,1,%%a) do (
set /a i+=1
set /a ans=%%a*%%b
set ans=%%b×%%a=!ans!
set res=!res! !ans:~0,6!
if !i! equ %%a echo!res!&set res=& set i=0
pause
