阅读:2396回复:0
计算字符串的长度的多种解决方案集锦
更多 发布于:2013-06-05 10:52
@echo off
:: Based on willsort's codes code by JM 2006-10-9 CMD@XP
:: 出处:http://www.cn-dos.net/forum/viewthread.php?tid=19819
set mystr=
set /p mystr=输入要计算长度的字符串(直接回车退出):
if not defined mystr goto :eof
set count=0
setlocal enabledelayedexpansion
:intercept
set /a count+=1
for /f %%i in ("%count%") do if not "!mystr:~%%i,1!"=="" goto intercept
echo 长 度: %count%
pause
goto :eof
@echo off
:began
set /p mystr=输入要计算长度的字符串:
echo %mystr:~0,1% | findstr /i "q" 1>nul 2>nul && exit rem 输入q退出
call :bflen "%mystr%" rem 这两句调用bflen,返回长度到变量ret中。
echo 字符串: "%mystr%"
echo 长 度: %ret%
goto began
:bflen rem 真麻烦,初始化要单独拿出来。
set num=
set str=
set ret=
set str=%1
:len rem 计算字符串长度
set str=%str:~0,-1%
set /a num = %num% + 1
if defined str goto len
set /a ret = %num% - 2
set num=
goto :eof
