阅读:2966回复:0
显示随机的5个数
更多 发布于:2013-06-05 11:00
@echo off
:: 求1-100范围内随机的不同5个数值
:: 生成0-99之间的随机数列 R1
@echo off
setlocal EnableDelayedExpansion
:: 初始化顺序数列
for /l %%i in (0,1,99) do (
set rnum%%i=%%i
:: 对数列进行随机交换
set /a rnd=!random! %% 100
call set tmp=%%rnum!rnd!%%
set rnum!rnd!=!rnum%%i!
set rnum%%i=!tmp!
set rnum
pause
goto :eof
@echo off
:: Code by JM 2006-1-5 CMD@XP
:begin
cls
set times=0
set count=0
:loop
set /a num=%random%%%99+1
if not defined num%num% (
set num%num%=%num%
set /a count+=1
call echo %%num%%
set /a times+=1
if %times% equ 20 (
for /l %%i in (1,1,99) do set num%%i=
set times=0
if %count% lss 5 goto loop
pause>nul
goto begin
@echo off
:: Code by JM 2007-1-6 CMD@XP
:: 因为用到了 echo|find 的结构,速度比较慢
:begin
cls
set count=0
:loop
set /a num=%random%%%100+1
echo %str%|find " %num% ">nul&&goto loop
call set str=%%str%% %num%
set /a count+=1
echo %str%
set str=
pause
goto begin
@echo off&setlocal enabledelayedexpansion
for /l %%a in (1;1;5) do (
set/a b=!random!%%99+1
call :pp !b!
goto :eof
:pp
if not defined %1 (set %1=a) else goto loop
echo %1
goto :eof
:loop
call :pp !b!
@echo off
set Max=100
set N=5
:start
cls
echo %time%
set Num=
set Tmp$=
:loop
set /a randomloop=(%random%+%random%+%random%)/3%%%Max%+1
for %%n in (%Tmp$%) do if "%randomloop%" == "%%n" goto loop
call set Tmp$=%%Tmp$%% %randomloop%
set /a Num+=1
set random_%Num%=%randomloop%
if %Num% LSS %N% goto loop
echo %Tmp$%
echo %time%
pause
goto start
exit
@echo off
:start
cls
set Num=
set Tmp$=
:loop
set /a randomloop=%random%%%99+1
set /a Num+=1
if %Num% LSS 5 goto loop
for /l %%n in (1,1,%Num%) do call set /p= %%random_%%n%%echo.
pause
goto start
exit
