阅读:3500回复:0
[C++技术]观察者模式 C++ 实现
更多 发布于:2013-06-17 10:54
[cpp]
#include<iostream>
#include<string>
#include<list>
#include<algorithm>
  气象监控应用问题 (head first 设计模式案例)
using namespace std;
class observer   //观察者公共接口
  public:
         virtual void update(float tmp, float humidity, float pressure) {}
class subject    //主题公共接口     问题:成员函数为什么不能用纯虚函数?
{ public:
  virtual void register_observer(observer o) {}
  virtual void remove_observer(observer o){}
  virtual void notify_observer() {}
class display_element   //显示公共接口
  public:
       virtual void display() = 0;
class weatherdata : public subject   //具体主题
  private:
    float temperature;
    float humidity;
    float pressure;
    list<observer*> *observers;
  public:
    weatherdata()
      observers = new list<observer*>;
    void register_observer(observer* o)  //将观察者注册到观察者列表中
      (*observers).push_back(o);
    void remove_observer(observer* o)
    { list<observer*>::iterator it;
      it = find((*observers).begin(),(*observers).end(),o);
      (*observers).erase(it);
    void notify_observer()     //通知观察者
    { list<observer*>::iterator ite;
      ite = observers->begin();
      for(; ite != observers->end(); ite++)
        (*ite)->update(temperature,humidity,pressure);
    void set_measurements(float temperature, float humidity, float pressure)
      this->temperature = temperature;
      this->humidity = humidity;
      this->pressure = pressure;
      notify_observer();    //更新了随时通知观察者
class currentconditiondisplay: public observer, public display_element  //具体观察者 ,同时继承了显示公共接口
  private:
        float temperature;
        float humidity;
        float pressure;
        weatherdata *weatherstation;
  public:
        currentconditiondisplay(weatherdata *weatherstation)
          this->weatherstation = weatherstation;
          weatherstation->register_observer(this);    //是不是因为继承了observer接口才能注册?
        void update(float temperature, float humidity, float pressure)
          display();
       void display()
         cout <<"current condition: "<< endl;
         cout <<"temperature: " <<temperature<< endl;
         cout <<"humidity:" <<humidity<< endl;
         cout <<"pressure:" << pressure<< endl;
//  客户端
int main()
  weatherdata *weather_station = new weatherdata();    // 用new时,一定要记住返回的是指针!
  currentconditiondisplay *display = new currentconditiondisplay(weather_station);
  weather_station->set_measurements(89.67,33.56,56.98);
  weather_station->set_measurements(11,34.01,39);
  system("pause");
  return 0;
#include<iostream>
#include<string>
#include<list>
#include<algorithm>
  public:
{ public:
  public:
  private:
    float temperature;
    float humidity;
    float pressure;
  public:
    weatherdata()
  private:
        float temperature;
        float humidity;
        float pressure;
  public:
          display();
       void display()
//  客户端
int main()
  system("pause");
  return 0;
