阅读:3134回复:0
[mysql]Linux MySQL密码修改
更多 发布于:2013-06-17 11:11
Linux MySQL密码修改
1)如果您没有忘记密码的情况下,可以通过UPDATE直接编辑user表来修改密码:
进入数据库mysql -u root
mysql> use mysql;
mysql> UPDATE user SET Password = PASSWORD('newpass') WHERE user = 'root';
mysql> FLUSH PRIVILEGES;
 /etc/init.d/mysql stop
 /etc/init.d/mysql start
2)如果您已经忘记密码:
# /etc/init.d/mysql stop                                   1、结束当前正在运行的mysql进程。
# /usr/bin/mysqld_safe --skip-grant-tables     2、用mysql安全模式运行并跳过权限验证。
# mysql -u root                                               3、重开一个终端以root身份登录mysql。
mysql> use mysql;                                          4、修改root用户口令。
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> update user set Password = PASSWORD('root') where User ='root';
Query OK, 3 rows affected (0.00 sec)
Rows matched: 3 Changed: 3 Warnings: 0
mysql> exit
# /etc/init.d/mysql restart                                5、结束mysql安全模式,用正常模式运行mysql。
mysql> update mysql.user set password=PASSWORD('新密码') where User='root';
        6、试试你新修改的口令
mysql> flush privileges;
mysql> quit
