阅读:3649回复:0
[C语言]mac下Des CBC加密
更多 发布于:2013-07-08 13:08
加密步骤如下:
1)首先将数据按照8个字节一组进行分组得到D1D2......Dn(若数据不是8的整数倍,用指定的PADDING数据补位)
2)第一组数据D1与初始化向量I异或后的结果进行DES加密得到第一组密文C1(初始化向量I为全零)
3)第二组数据D2与第一组的加密结果C1异或以后的结果进行DES加密,得到第二组密文C2
4)之后的数据以此类推,得到Cn
5)按顺序连为C1C2C3......Cn即为加密结果。
3Des.h文件
[cpp]
#ifndef _3DES
#define _3DES
#include <strings.h>
#ifdef __cplusplus
extern "C"
#endif /* __cplusplus */
    unsigned char* GetKey(unsigned char *RandomData);
    void  DesEncrypt_ECB(unsigned char *key, unsigned char *data);
    unsigned char* DesEncrypt_CBC(unsigned char *key, unsigned char *data,int len);
#ifdef __cplusplus
#endif /* defined(_3DES) */
#ifndef _3DES
#define _3DES
#ifdef __cplusplus
extern "C"
#ifdef __cplusplus
3Des.cpp文件
[cpp]
#include "3DES.h"
#include "DES.h"
#include <iostream>
unsigned char* GetKey(unsigned char *RandomData){
    unsigned char* key=(unsigned char*)malloc(16);
    for (int i=0; i<16; i++) {
        key=0xFF;
    unsigned char RevertData[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
    for (int i=0; i<sizeof(RevertData); i++) {
        RevertData=~RandomData;
    DesEncrypt_ECB(key, RandomData);
    DesEncrypt_ECB(key, RevertData);
        if(i<8)
            key=RandomData;
        else
            key=RevertData[i-8];
    return key;
void  DesEncrypt_ECB(unsigned char *key, unsigned char *data){
    DesEncrypt(key,data);
    DesDecrypt(key,data);
unsigned char*  DesEncrypt_CBC(unsigned char *key, unsigned char *data, int len){
    unsigned char* data2=(unsigned char*)malloc(8);
    unsigned char data3[8];
    int sum=len/8+1;
    int yushu=len%8;
    for (int i=0;i<sum;i++) {
        for (int j=0; j<8; j++) {
            if(i<sum-1){
                data2[j]=data[i*8+j];
                if(j==7&&i==0){
                    DesEncrypt(key, data2);
                    for (int k=0; k<8; k++) {
                        data3[k]=data2[k];
                }else if(j==7&&i>0){
                        data2[k]^=data3[k];
                        data3[k]=data2[k];
            }else if(yushu==0&&i==sum-1&&j==7){
                data2[0]=0x80;
                for(int k=1;k<8;k++){
                    data2[k]=0x00;
                    data2[k]^=data3[k];
            }else if(yushu>0){
                if(j<yushu){
                }else if(j==yushu){
                    data2[j]=0x80;
                }else if(j>yushu&&j!=7){
                    data2[j]=0x00;
                }else if(j==7){
                    data2[j]=0x00;
                        data2[k]^=data3[k];
    return data2;
#include "3DES.h"
#include "DES.h"
#include <iostream>
        key=0xFF;
        if(i<8)
            key=RandomData;
        else
    return key;
    int sum=len/8+1;
    int yushu=len%8;
            if(i<sum-1){
                if(j==7&&i==0){
                        data3[k]=data2[k];
                        data2[k]^=data3[k];
                        data3[k]=data2[k];
    data2[0]=0x80;
     data2[k]=0x00;
                    data2[k]^=data3[k];
            }else if(yushu>0){
                if(j<yushu){
                }else if(j==yushu){
                    data2[j]=0x80;
                    data2[j]=0x00;
                }else if(j==7){
                    data2[j]=0x00;
                        data2[k]^=data3[k];
    return data2;
main函数
[cpp]
unsigned char RandomData[16]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
    unsigned char* key=GetKey(RandomData);
    unsigned char data[17]={0x14,0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
    unsigned char* macdata=DesEncrypt_CBC(key,data,sizeof(data));
    for (int i=0; i<8; i++) {
        printf("%x\n",macdata);
    free(macdata);
    free(key);
    free(macdata);
    free(key);
