阅读:3690回复:0
[C++技术]C++ I/O操作——简单文件加密
更多 发布于:2013-07-08 13:09
[cpp]
#include<iostream>
#include<fstream>
#include<string>
  实现对输入文件进行简单加密和解密,然后输出到输出文件。
  解密时密码需要和加密时密码一致。
using namespace std;
int main()
{   string str;
    char buffer[256];
    int psw;  int a;
    cout <<"encode or decode ? if encode, please input 1 else decode input 2 :"<<endl;  // encode or decode ?
    cin >> a;                                                      //
    cout <<"please input the psw:"<<endl;                            // input psw
    cin >> psw;
    if(a == 2)
        psw = 0 - psw;
    cout <<"please input the filename of source...."<<endl;           // input source file
    cin >> str;
    fstream outfile(str.c_str(), ios::in);
    cout <<"please input the filename of destinity...."<<endl;       // input destiny file
    cin >> str;
    ofstream outtxt(str.c_str(),ios::ate| ios::out );
    while(!outfile.eof())                                         // process
      cout <<"222"<<endl;
      outfile.getline(buffer, 256,'\n');
      cout << buffer <<endl;
      for(int i = 0; i < strlen(buffer); i++)                   //algorithm of encode or decode
      buffer = buffer + psw;
      outtxt << buffer <<endl;
    outfile.clear();
    outfile.close();
    return 0;
#include<iostream>
#include<fstream>
#include<string>
  解密时密码需要和加密时密码一致。
int main()
{   string str;
    char buffer[256];
 int psw;  int a;
 cin >> a;                                                      //
 cin >> psw;
 if(a == 2)
  psw = 0 - psw;
 cin >> str;
 cin >> str;
   cout <<"222"<<endl;
 outfile.clear();
 outfile.close();
    return 0;
}算是文件加密入门。
