阅读:4773回复:0
[mysql]mysql函数实例-统计1周内未登陆的用户
更多 发布于:2013-07-15 13:56
mysql函数实例-统计月登陆用户数
统计月使用用户数,仅作备忘。
[code ]java代码
CREATE FUNCTION  statics_user_login_month() RETURNS int(11)
    COMMENT '月使用用户数\r\n'
BEGIN
    #Routine body goes here...
    DECLARE stopFlag INT DEFAULT 0 ;
    DECLARE _shop_id INT(11) DEFAULT 0;
    DECLARE _device VARCHAR(50);
    DECLARE _a_token CHAR(64) DEFAULT '-1';
    DECLARE _s_token VARCHAR(64) DEFAULT NULL;
    DECLARE _use_count INT(11) DEFAULT 0;
    DECLARE _month_time date;
    #统计上月的食客登录用户
    DECLARE cur1 CURSOR FOR SELECT id, device, a_token, s_token FROM visitor_user
        WHERE DATE_FORMAT(off_time, '%Y-%m') = DATE_FORMAT((curdate() - 1), '%Y-%m');
    DECLARE CONTINUE HANDLER FOR NOT FOUND SET stopFlag=1;
    OPEN cur1;
    FETCH cur1 INTO _shop_id, _device, _a_token, _s_token;
    WHILE  stopFlag = 0 do
        INSERT INTO report_user_login_month_detail(id, shop_id, month_time, device, a_token, s_token)
            VALUES (UUID(), _shop_id, DATE_FORMAT((curdate() - 1), '%Y-%m'), _device, _a_token, _s_token);
    END WHILE;
  CLOSE cur1;
    set _month_time = DATE_FORMAT((curdate() - 1), '%Y-%m');
    #统计上月登录用户数
    SELECT COUNT(device) INTO _use_count FROM visitor_user
        WHERE DATE_FORMAT(off_time, '%Y-%m') = _month_time;
    INSERT INTO report_user_login_month(id, month_time, use_count, type_client)
        VALUES(UUID(), _month_time, _use_count, 0);
    RETURN 1;
END[/code]
