阅读:3941回复:0
[mysql]mysql函数实例-统计日新增用户
更多 发布于:2013-07-15 13:57
mysql函数实例-统计日新增用户
[code ]Sql代码
CREATE FUNCTION `statics_user_new`() RETURNS int(11)
    COMMENT '统计新增用户'
BEGIN
    #Routine body goes here...
    DECLARE stopFlag INT DEFAULT 0 ;
    DECLARE _shop_id VARCHAR(11) DEFAULT NULL;  #餐厅id
    DECLARE _device VARCHAR(50) DEFAULT NULL;   #手机设备号
    DECLARE _a_token CHAR(64) DEFAULT NULL;     #与苹果服务器会话
    DECLARE _s_token VARCHAR(64) DEFAULT NULL;  #与点菜网服务器会话
    DECLARE _counts INT DEFAULT 0;
    #查询昨天新创建的用户
    DECLARE cur1 CURSOR FOR SELECT id, device, a_token, s_token FROM visitor_user
        where DATE_FORMAT(create_time, '%Y-%m-%d') = DATE_SUB(DATE_FORMAT(now(),'%Y-%m-%d'), interVAL 1 DAY);
    DECLARE CONTINUE HANDLER FOR NOT FOUND SET stopFlag=1;
    OPEN cur1;
    FETCH cur1 INTO _shop_id, _device, _a_token, _s_token;
    WHILE  stopFlag = 0 do
        INSERT INTO report_user_new_day_detail(id, shop_id, device, a_token, s_token)
            values (UUID(), _shop_id, _device, _a_token, _s_token);
    END WHILE;
    CLOSE cur1;
    #统计日新增用户数
    SELECT COUNT(device) INTO _counts FROM visitor_user
        where DATE_FORMAT(create_time, '%Y-%m-%d') = DATE_SUB(DATE_FORMAT(now(),'%Y-%m-%d'), INTERVAL 1 DAY);
    INSERT INTO report_user_new_day(id, day_time, new_counts, type_client)
        VALUES(UUID(), DATE_SUB(DATE_FORMAT(now(),'%Y-%m-%d'), INTERVAL 1 DAY), _counts, 0);
    SET _counts = 1;
    RETURN _counts;
END[/code]
