111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:9770回复:0
c# gridview 排序及分页_c#应用
更多 发布于:2011-01-08 21:11
如果你在GridView控件上设置 AllowPaging="true" or AllowSorting="true" 而没有使用使用数据源控件 DataSource (i.e. SqlDataSource, ObjectDataSource),运行则会出现下列错误:
当你在GridView控件上单击下一页时:
The GridView GridViewID fired event PageIndexChanging which wasnt handled.
当你点击排序时,则回出现:
The GridView GridViewID fired event Sorting which wasnt handled.
如果你没有设置GridView的DataSourceID 的属性,你必须添加一个操作才能排序及分页。。
 点这里查看下面的例子
<%@ Page Language="C#" %>
<%@ Import Namespace="System.Data" %>
<%@ Import Namespace="System.Data.OleDb" %>
<script runat="server">
   private void PopulatePublishersGridView()
       string connectionString = AccessConnectionString();
       OleDbConnection accessConnection = new OleDbConnection(connectionString);
       string sqlQuery = "SELECT [PubID], [Name], [Company Name], [Address], [City], [State], [Zip], [Telephone], [Fax], [Comments] FROM Publishers ORDER BY [Name] ASC;";
       OleDbCommand accessCommand = new OleDbCommand(sqlQuery, accessConnection);
       OleDbDataAdapter publishersDataAdapter = new OleDbDataAdapter(accessCommand);
       DataTable publishersDataTable = new DataTable("Publishers");
       publishersDataAdapter.Fill(publishersDataTable);
       int dataTableRowCount = publishersDataTable.Rows.Count;
       if (dataTableRowCount > 0)
           gridViewPublishers.DataSource = publishersDataTable;
           gridViewPublishers.DataBind();
   private string AccessConnectionString()
       string accessDatabasePath = Server.MapPath("~/App_Data/biblio.mdb");
       return String.Format("Provider=Microsoft.Jet.OLEDB.4.0;Data Source={0};", accessDatabasePath);
   private string GridViewSortDirection
       get { return ViewState["SortDirection"] as string ?? "ASC"; }
       set { ViewState["SortDirection"] = value; }
   private string GridViewSortExpression
       get { return ViewState["SortExpression"] as string ?? string.Empty; }
       set { ViewState["SortExpression"] = value; }
   private string GetSortDirection()
       switch (GridViewSortDirection)
           case "ASC":
               GridViewSortDirection = "DESC";
               break;
           case "DESC":
               GridViewSortDirection = "ASC";
               break;
       return GridViewSortDirection;
   protected void gridViewPublishers_PageIndexChanging(object sender, GridViewPageEventArgs e)
       gridViewPublishers.DataSource = SortDataTable(gridViewPublishers.DataSource as DataTable, true);
       gridViewPublishers.PageIndex = e.NewPageIndex;
   protected DataView SortDataTable(DataTable dataTable, bool isPageIndexChanging)
       if (dataTable != null)
           DataView dataView = new DataView(dataTable);
           if (GridViewSortExpression != string.Empty)
               if (isPageIndexChanging)
                   dataView.Sort = string.Format("{0} {1}", GridViewSortExpression, GridViewSortDirection);
               else
                   dataView.Sort = string.Format("{0} {1}", GridViewSortExpression, GetSortDirection());
           return dataView;
       else
           return new DataView();
   protected void gridViewPublishers_Sorting(object sender, GridViewSortEventArgs e)
       GridViewSortExpression = e.SortExpression;
       int pageIndex = gridViewPublishers.PageIndex;
       gridViewPublishers.DataSource = SortDataTable(gridViewPublishers.DataSource as DataTable, false);
       gridViewPublishers.PageIndex = pageIndex;
   protected void Page_Load(object sender, EventArgs e)
       PopulatePublishersGridView();
</script>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
   <title>GridView Sorting/Paging without a DataSourceControl DataSource</title>
</head>
<body>
   <form id="form" runat="server">
       <div>
           <asp:GridView ID="gridViewPublishers" AllowPaging="true" AllowSorting="true" AutoGenerateColumns="false"
               EmptyDataText="No records found" PagerSettings-Mode="NumericFirstLast" PageSize="25"
               OnPageIndexChanging="gridViewPublishers_PageIndexChanging"
               runat="server">
               <AlternatingRowStyle BackColor="LightGray" />
               <HeaderStyle BackColor="Gray" Font-Bold="true" Font-Names="Verdana" Font-Size="Small" />
               <PagerStyle BackColor="DarkGray" Font-Names="Verdana" Font-Size="Small" />
               <RowStyle Font-Names="Verdana" Font-Size="Small" />
               <Columns>
                   <asp:BoundField DataField="PubID" HeaderText="Publisher ID" SortExpression="PubID" />
                   <asp:BoundField DataField="Name" HeaderText="Name" SortExpression="Name" />
                   <asp:BoundField DataField="Company Name" HeaderText="Company Name" SortExpression="Company Name" />
                   <asp:BoundField DataField="Address" HeaderText="Address" SortExpression="Address" />
                   <asp:BoundField DataField="City" HeaderText="City" SortExpression="City" />
                   <asp:BoundField DataField="State" HeaderText="State" SortExpression="State" />
                   <asp:BoundField DataField="Zip" HeaderText="Zip" SortExpression="Zip" />
                   <asp:BoundField DataField="Telephone" HeaderText="Telephone" SortExpression="Telephone" />
                   <asp:BoundField DataField="Fax" HeaderText="Fax" SortExpression="Fax" />
                   <asp:BoundField DataField="Comments" HeaderText="Comments" SortExpression="Comments" />
               </Columns>
           </asp:GridView>
       </div>
   </form>
</body>
</html>
http://www.cnblogs.com/cygoodyu/archive/2006/11/29/575825.html
更多黑客技术 黑客软件 计算机技术 编程技术 网站技术 qq技术 IT新闻 黑客基地 请访问 灯火安全联盟  灯火黑客 www.hack8888.com/bbs
