阅读:4157回复:0
破解MAC苹果电脑系统密码的方法步骤
更多 发布于:2013-08-26 10:14
破解苹果电脑系统密码的方法步骤
1、开机按住option 选择进入  recovery hd .
2、然后选择菜单栏上的 实用工具 - 终端
3、在终端内输入:resetpassword
4、然后设置您新的帐户密码,重启进入系统
5、进入系统后,总会提示 :Mac OS X want to use the "login" keychain?
6、Open   Applications/Utilities/Keychain Access.app
In Keychain Access, choose Preferences from the Keychain Access menu.
If available, click the Reset My Default Keychain button. This will remove the login keychain and create a new one with the password provided.
If Reset My Default Keychain is not available, choose Keychain List from the Edit menu.
Delete the "login" keychain.
