111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:5480回复:1
c#入门代码_c#应用
更多 发布于:2011-01-26 21:45
一、从控制台读取东西代码片断:
using System;
class TestReadConsole
    public static void Main()
        Console.Write(Enter your name:);
        string strName = Console.ReadLine();
        Console.WriteLine( Hi + strName);
二、读文件代码片断:
using System;
using System.IO;
public class TestReadFile
    public static void Main(String[] args)
        // Read text file C:\temp\test.txt
        FileStream fs = new FileStream(@c:\temp\test.txt , FileMode.Open, FileAccess.Read);
        StreamReader sr = new StreamReader(fs);
        String line=sr.ReadLine();
        while (line!=null)
            Console.WriteLine(line);
            line=sr.ReadLine();
        sr.Close();
        fs.Close();
三、写文件代码:
using System;
using System.IO;
public class TestWriteFile
        // Create a text file C:\temp\test.txt
        FileStream fs = new FileStream(@c:\temp\test.txt , FileMode.OpenOrCreate, FileAccess.Write);
        StreamWriter sw = new StreamWriter(fs);
        // Write to the file using StreamWriter class
        sw.BaseStream.Seek(0, SeekOrigin.End);
        sw.WriteLine( First Line );
        sw.WriteLine( Second Line);
        sw.Flush();
四、拷贝文件:
using System;
using System.IO;
class TestCopyFile
        File.Copy(c:\\temp\\source.txt, C:\\temp\\dest.txt );
五、移动文件:
using System;
using System.IO;
class TestMoveFile
        File.Move(c:\\temp\\abc.txt, C:\\temp\\def.txt );
六、使用计时器:
using System;
using System.Timers;
class TestTimer
        Timer timer = new Timer();
        timer.Elapsed += new ElapsedEventHandler( DisplayTimeEvent );
        timer.interval = 1000;
        timer.Start();
        timer.Enabled = true;
       while ( Console.Read() != q )
    public static void DisplayTimeEvent( object source, ElapsedEventArgs e )
        Console.Write(\r{0}, DateTime.Now);
七、调用外部程式:
class Test
    static void Main(string[] args)
        System.Diagnostics.Process.Start(notepad.exe);
ADO.NET方面的:
八、连接Access数据库:
using System;
using System.Data;
using System.Data.OleDb;
class TestADO
        string strDSN = Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\\test.mdb;
        string strSQL = SELECT * FROM employees ;
       OleDbConnection conn = new OleDbConnection(strDSN);
        OleDbCommand cmd = new OleDbCommand( strSQL, conn );
        OleDbDataReader reader = null;
        try
            conn.Open();
            reader = cmd.ExecuteReader();
            while (reader.Read() )
                Console.WriteLine(First Name:{0}, Last Name:{1}, reader[FirstName], reader[LastName]);
        catch (Exception e)
            Console.WriteLine(e.Message);
        finally
            conn.Close();
九、连接SQL Server数据库:
using System;
using System.Data.SqlClient;
public class TestADO
        SqlConnection conn = new SqlConnection(Data Source=localhost; Integrated Security=SSPI; Initial Catalog=pubs);
        SqlCommand  cmd = new SqlCommand(SELECT * FROM employees, conn);
        try
            conn.Open();
           SqlDataReader reader = cmd.ExecuteReader();
            while (reader.Read())
                Console.WriteLine(First Name: {0}, Last Name: {1}, reader.GetString(0), reader.GetString(1));
            reader.Close();
            conn.Close();
        catch(Exception e)
            Console.WriteLine(Exception Occured -->> {0},e);
十、从SQL内读数据到XML:
using System;
using System.Data;
using System.Xml;
using System.IO;
public class TestWriteXML
       String strFileName=c:/temp/output.xml;
       SqlConnection conn = new SqlConnection(server=localhost;uid=sa;pwd=;database=db);
       String strSql = SELECT FirstName, LastName FROM employees;
       SqlDataAdapter adapter = new SqlDataAdapter();
       adapter.SelectCommand = new SqlCommand(strSql,conn);
       // Build the DataSet
        DataSet ds = new DataSet();
       adapter.Fill(ds, employees);
       // Get a FileStream object
        FileStream fs = new FileStream(strFileName,FileMode.OpenOrCreate,FileAccess.Write);
       // Apply the WriteXml method to write an XML document
        ds.WriteXml(fs);
       fs.Close();
十一、用ADO添加数据到数据库中:
using System;
using System.Data;
class TestADO
        string strDSN = Provider=Microsoft.Jet.OLEDB.4.0;DataSource=c:\test.mdb;
        string strSQL = INSERT INTO Employee(FirstName, LastName) VALUES(FirstName, LastName) ;
        // create Objects of ADOConnection and ADOCommand
        try
            conn.Open();
            cmd.ExecuteNonQuery();
        catch (Exception e)
            Console.WriteLine(Oooops. I did it again:\n{0}, e.Message);
        finally
            conn.Close();
十二、使用OLEConn连接数据库:
using System;
using System.Data;
class TestADO
        string strSQL = SELECT * FROM employee ;
        OleDbDataAdapter cmd = new OleDbDataAdapter( strSQL, conn );
       conn.Open();
        cmd.Fill( ds, employee );
        DataTable dt = ds.Tables[0];
       foreach( DataRow dr in dt.Rows )
            Console.WriteLine(First name: + dr[FirstName].ToString() + Last name: + dr[LastName].ToString());
        conn.Close();
十三、读取表的属性:
using System;
using System.Data;
class TestADO
       conn.Open();
       Console.WriteLine(Field Name DataType Unique AutoIncrement AllowNull);
        Console.WriteLine(==================================================================);
        foreach( DataColumn dc in dt.Columns )
            Console.WriteLine(dc.ColumnName+ , +dc.DataType + ,+dc.Unique + ,+dc.AutoIncrement+ ,+dc.AllowDBNull );
        conn.Close();
ASP.NET方面的
十四、一个ASP.NET程式:
<%@ Page Language=C# %>
<script runat=server>
    void Button1_Click(Object sender, EventArgs e)
        Label1.Text=TextBox1.Text;
</script>
<html>
<head>
</head>
<body>
    <form runat=server>
        <p>
            <br />
            Enter your name: <asp:TextBox id=TextBox1 runat=server></asp:TextBox>
        </p>
        <p>
            <b><asp:Label id=Label1 runat=server Width=247px></asp:Label></b>
        </p>
        <p>
            <asp:Button id=Button1 onclick=Button1_Click runat=server Text=Submit></asp:Button>
        </p>
    </form>
</body>
</html>
WinForm研发:
十五、一个简单的WinForm程式:
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.视窗系统.Forms;
using System.Data;
public class SimpleForm : System.视窗系统.Forms.Form
   private System.ComponentModel.Container components = null;
    private System.视窗系统.Forms.Button button1;
    private System.视窗系统.Forms.TextBox textBox1;
    public SimpleForm()
        InitializeComponent();
   protected override void Dispose( bool disposing )
        if( disposing )
            if (components != null)
                components.Dispose();
        base.Dispose( disposing );
   #region 视窗系统 Form Designer generated code
    private void InitializeComponent()
       this.components = new System.ComponentModel.Container();
        this.Size = new System.Drawing.Size(300,300);
        this.Text = Form1;
       this.button1 = new System.视窗系统.Forms.Button();
        this.textBox1 = new System.视窗系统.Forms.TextBox();
        this.SuspendLayout();
    // button1
   this.button1.Location = new System.Drawing.Point(8, 16);
    this.button1.Name = button1;
    this.button1.Size = new System.Drawing.Size(80, 24);
    this.button1.TabIndex = 0;
    this.button1.Text = button1;
    // textBox1
    this.textBox1.Location = new System.Drawing.Point(112, 16);
    this.textBox1.Name = textBox1;
    this.textBox1.Size = new System.Drawing.Size(160, 20);
    this.textBox1.TabIndex = 1;
    this.textBox1.Text = textBox1;
    // Form1
   this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
    this.ClientSize = new System.Drawing.Size(292, 273);
    this.Controls.AddRange(new System.视窗系统.Forms.Control[] {
    this.textBox1,
    this.button1});
    this.Name = Form1;
    this.Text = Form1;
    this.ResumeLayout(false);
    #endregion
   [STAThread]
    static void Main()
        Application.Run(new SimpleForm());
十六、运行时显示自己定义的图标:
//load icon and set to form
System.Drawing.Icon ico = new System.Drawing.Icon(@c:\temp\app.ico);
this.Icon = ico;
十七、添加组件到ListBox中:
private void Form1_Load(object sender, System.EventArgs e)
    string str = First item;
    int i = 23;
    float flt = 34.98f;
    listBox1.Items.Add(str);
    listBox1.Items.Add(i.ToString());
    listBox1.Items.Add(flt.ToString());
    listBox1.Items.Add(Last Item in the List Box);
网络方面的:
十八、取得IP地址:
using System;
using System.Net;
class GetIP
         IPHostEntry ipEntry = Dns.GetHostByName (localhost);
         IPAddress [] IpAddr = ipEntry.AddressList;
         for (int i = 0; i < IpAddr.Length; i++)
             Console.WriteLine (IP Address {0}: {1} , i, IpAddr.ToString ());
十九、取得机器名称:
using System;
using System.Net;
class GetIP
          Console.WriteLine (Host name : {0}, Dns.GetHostName());
二十、发送邮件:
using System;
using System.web;
using System.Web.Mail;
public class TestSendMail
        try
            // Construct a new mail message
            MailMessage message = new MailMessage();
            message.From = from@domain.com;
            message.To   =  pengyun@cobainsoft.com;
            message.Cc   = ;
            message.Bcc  = ;
            message.Subject = Subject;
            message.Body = Content of message;
            //if you want attach file with this mail, add the line below
            message.Attachments.Add(new MailAttachment(c:\\attach.txt, MailEncoding.Base64));
            // Send the message
            SmtpMail.Send(message);
            System.Console.WriteLine(Message has been sent);
       catch(Exception ex)
            System.Console.WriteLine(ex.Message.ToString());
二十一、根据IP地址得出机器名称:
using System;
using System.Net;
class ResolveIP
         IPHostEntry ipEntry = Dns.Resolve(172.29.9.9);
         Console.WriteLine (Host name : {0}, ipEntry.HostName);
GDI+方面的:
二十二、GDI+入门介绍:
using System;
using System.Data;
public class Form1 : System.视窗系统.Forms.Form
   public Form1()
        if( disposing )
        this.Name = Form1;
        this.Text = Form1;
        this.Paint += new System.视窗系统.Forms.PaintEventHandler(this.Form1_Paint);
    #endregion
   [STAThread]
    static void Main()
        Application.Run(new Form1());
   private void Form1_Paint(object sender, System.视窗系统.Forms.PaintEventArgs e)
        Graphics g=e.Graphics;
        g.DrawLine(new Pen(Color.Blue),10,10,210,110);
        g.DrawRectangle(new Pen(Color.Red),10,10,200,100);
        g.DrawEllipse(new Pen(Color.Yellow),10,150,200,100);
XML方面的:
二十三、读取XML文件:
using System;
using System.Xml;
class TestReadXML
        XmlTextReader reader  = new XmlTextReader(C:\\test.xml);
        reader.Read();
            reader.MoveToElement();
            Console.WriteLine(XmlTextReader Properties Test);
            Console.WriteLine(===================);
           // Read this properties of element and display them on console
            Console.WriteLine(Name: + reader.Name);
            Console.WriteLine(Base URI: + reader.BaseURI);
            Console.WriteLine(Local Name: + reader.LocalName);
            Console.WriteLine(Attribute Count: + reader.AttributeCount.ToString());
            Console.WriteLine(Depth: + reader.Depth.ToString());
            Console.WriteLine(Line Number: + reader.LineNumber.ToString());
            Console.WriteLine(Node Type: + reader.NodeType.ToString());
            Console.WriteLine(Attribute Count: + reader.Value.ToString());
二十四、写XML文件:
using System;
using System.Xml;
public class TestWriteXMLFile
    public static int Main(string[] args)
        try
            // Creates an XML file is not exist
            XmlTextWriter writer = new XmlTextWriter(C:\\temp\\xmltest.xml, null);
            // Starts a new document
            writer.WriteStartDocument();
            //Write comments
            writer.WriteComment(Commentss: XmlWriter Test Program);
            writer.WriteProcessingInstruction(Instruction,Person Record);
            // Add elements to the file
            writer.WriteStartElement(p, person, urn:person);
            writer.WriteStartElement(LastName,);
            writer.WriteString(Chand);
            writer.WriteEndElement();
            writer.WriteStartElement(FirstName,);
            writer.WriteString(Mahesh);
            writer.WriteElementInt16(age,, 25);
            // Ends the document
            writer.WriteEndDocument();
        catch (Exception e)
            Console.WriteLine (Exception: {0}, e.ToString());
        return 0;
Web Service方面的:
二十五、一个Web Service的小例子:
<% @WebService Language=C# Class=TestWS %>
using System.Web.Services;
public class TestWS : System.Web.Services.WebService
    [WebMethod()]
    public string StringFromWebService()
        return This is a string from web service.;
停止后开始
  • 注册日期2011-06-05
  • 发帖数12
  • 火币22枚
  • 粉丝6
  • 关注6
发布于:2011-07-07 11:39
哎…我一小菜菜
