111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:4083回复:0
常用PHP代码
更多 发布于:2011-01-26 22:11
这是一些使用频率比较高的php函数......
1.产生随机字符串函数
function random($length) {
 $hash = @#@#;
 $chars = @#ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789abcdefghijklmnopqrstuvwxyz@#;
 $max = strlen($chars) - 1;
 mt_srand((double)microtime() * 1000000);
 for($i = 0; $i < $length; $i++) {
  $hash .= $chars[mt_rand(0, $max)];
 return $hash;
2.截取一定长度的字符串
注:该函数对GB2312使用有效
function wordscut($string, $length ,$sss=0) {
 if(strlen($string) > $length) {
               if($sss){
                      $length=$length - 3;
                      $addstr=@# ...@#;
   if(ord($string[$i]) > 127) {
    $wordscut .= $string[$i].$string[$i + 1];
    $i++;
   } else {
    $wordscut .= $string[$i];
  return $wordscut.$addstr;
 return $string;
3.取得客户端IP地址
function GetIP(){
             if (getenv("HTTP_CLIENT_IP") ;; strcasecmp(getenv("HTTP_CLIENT_IP"), "unknown"))
                   $ip = getenv("HTTP_CLIENT_IP");
             else if (getenv("HTTP_X_FORWARDED_FOR") ;; strcasecmp(getenv("HTTP_X_FORWARDED_FOR"), "unknown"))
                   $ip = getenv("HTTP_X_FORWARDED_FOR");
             else if (getenv("REMOTE_ADDR") ;; strcasecmp(getenv("REMOTE_ADDR"), "unknown"))
                   $ip = getenv("REMOTE_ADDR");
             else if (isset($_SERVER[@#REMOTE_ADDR@#]) ;; $_SERVER[@#REMOTE_ADDR@#] ;; strcasecmp($_SERVER[@#REMOTE_ADDR@#], "unknown"))
                   $ip = $_SERVER[@#REMOTE_ADDR@#];
             else
                  $ip = "unknown";
             return($ip);
4.创建相应的目录
function createdir($dir=@#@#)
        if (!is_dir($dir))
            $temp = explode(@#/@#,$dir);
            $cur_dir = @#@#;
            for($i=0;$i<count($temp);$i++)
                $cur_dir .= $temp[$i].@#/@#;
                if (!is_dir($cur_dir))
                @mkdir($cur_dir,0777);
5.判断邮箱地址
function checkEmail($inAddress)
 return (ereg("^([a-zA-Z0-9_-])+@([a-zA-Z0-9_-])+(\.[a-zA-Z0-9_-])+",$inAddress));
6.跳转
function gotourl($message=@#@#,$url=@#@#,$title=@#@#)
    $html  ="<html><head>";
    if(!empty($url))
     $html .="<meta http-equiv=@#refresh@# content=\"3;url=@#".$url."@#\">";
    $html .="<link href=@#../templates/style.css@# type=text/css rel=stylesheet>";
    $html .="</head><body><br><br><br><br>";
    $html .="<table cellspacing=@#0@# cellpadding=@#0@# border=@#1@# width=@#450@# align=@#center@#>";
 $html .="<tr><td bgcolor=@##ffffff@#>";
 $html .="<table border=@#1@# cellspacing=@#1@# cellpadding=@#4@# width=@#100%@#>";
 $html .="<tr class=@#m_title@#>";
 $html .="<td>".$title."</td></tr>";
 $html .="<tr class=@#line_1@#><td align=@#center@# height=@#60@#>";
 $html .="<br>".$message."<br><br>";
    if (!empty($url))
     $html .="系统将在3秒后返回<br>如果你的浏览器不能自动返回,请点击[<a href=".$url." target=_self>这里</a>]进入";
    else
     $html .="[<a href=@##@# ōnclick=@#history.go(-1)@#>返回</a>]";
    $html .="</td></tr></table></td></tr></table>";
 $html .="</body></html>";
 echo $html;
 exit;
7.分页(两个函数配合使用)
function getpage($sql,$page_size=20)
      global $page,$totalpage,$sums;  //out param
      $page = $_GET["page"];
      //$eachpage = $page_size;
      $pagesql = strstr($sql," from ");
      $pagesql = "select count(*) as ids ".$pagesql;
      $result = mysql_query($pagesql);
      if($rs = mysql_fetch_array($result)) $sums = $rs[0];
      $totalpage = ceil($sums/$page_size);
      if((!$page)||($page<1)) $page=1;
   $startpos = ($page-1)*$page_size;
   $sql .=" limit $startpos,$page_size ";
    return $sql;
function showbar($string="")
    global $page,$totalpage;
 $out="共<font ".$totalpage."color=@#red@#><b>".$totalpage."</b></font>页  ";
    $linkNum =4;
    $start = ($page-round($linkNum/2))>0 ? ($page-round($linkNum/2)) : "1";
    $end   = ($page+round($linkNum/2))<$totalpage ? ($page+round($linkNum/2)) : $totalpage;
    $prestart=$start-1;
    $nextend=$end+1;
    if($page<>1)
 $out .= "<a href=@#?page=1;;".$string."@#title=第一页>第一页</a> ";
    if($start>1)
 $out.="<a href=@#?page=".$prestart."@# title=上一页>..<<</a> ";
 for($t=$start;$t<=$end;$t++)
     $out .= ($page==$t) ? "<font [".$t."]color=@#red@#><b>[".$t."]</b></font> " : "<a $thref=@#?page=$t;;".$string."@#>$t</a> ";
 if($end<$totalpage)
 $out.="<a href=@#?page=".$nextend.";;".$string."@# title=下一页>>>..</a>";
    if($page<>$totalpage)
   $out .= " <a href=@#?page=".$totalpage.";;".$string."@# title=最后页>最后页</a>";
   return $out;
8.获取新插入数据的ID
mysql_insert_id();
