111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:4309回复:0
把文章内容中涉及到的图片自动保存到本地服务器 _asp技巧
更多 发布于:2011-01-26 22:17
const savepath="tempfile/"
function myreplace(str)
newstr=str
set objregEx = new RegExp
objregEx.IgnoreCase = true
objregEx.Global = true
objregEx.Pattern = "http://(.+?)\.(jpg|gif|png|bmp)"
set matches = objregEx.execute(str)
for each match in matches
newstr=replace(newstr,match.value,saveimg(match.value))
next
myreplace=newstr
end function
function saveimg(url)
temp=split(url,".")
randomize
ranNum=int(90000*rnd)+10000
filename=year(now);month(now);day(now);hour(now);minute(now);second(now);ranNum;".";temp(ubound(temp))
set xmlhttp=server.createobject("Microsoft.XMLHTTP")
xmlhttp.open "get",url,false
xmlhttp.send
if xmlhttp.status<>200 then
 saveimg=""
else
 img=xmlhttp.ResponseBody
 set objAdostream=server.createobject("ADODB.Stream")
 objAdostream.Open()
 objAdostream.type=1
 objAdostream.Write(img)
 objAdostream.SaveToFile(server.mappath("./";savepath;filename))
 objAdostream.SetEOS
 set objAdostream=nothing
 saveimg=savepath;filename
end if
set xmlhttp=nothing
end function
