111111
  • 注册日期2010-12-08
  • 发帖数640
  • 火币1103枚
  • 粉丝120
  • 关注75
阅读:3783回复:0
使用组件封装数据库操作(二)_asp技巧
更多 发布于:2011-01-26 22:20
前段日子发表的文章,数据库的连接代码能直接在ASP文件中显示出来。这次又进行了一次封装。
打开vb,新建Activex控件,工程名称为webDb,类模块名称为GetInfomation
引用”Microsoft Activex Data Object 2.6 Library ”
Private Conn As ADODB.Connection
Private Rs As ADODB.Recordset
‘作用:判断数据库是否正确连结
自己能更改连接串
Public Function GetConn()
Conn.Open "Provider=SQLOLEDB.1;Persist Security Info=False;User ID=sa;Initial Catalog=Northwind;Data Source=yang"
If Err.Number <> 0 Then
   GetConn = False
Else
   GetConn = True
End If
End Function
‘根据输入的雇员ID,得到雇员的名称
Public Function GetEmployeeName(strEmployeeID As Integer) As String
   Dim strSql As String
   Set rs = New ADODB.Recordset
   strSql = "select LastName+firstname from employees where EmployeeID=" ; strEmployeeID
   rs.Open strSql, Conn, adOpenStatic, adLockOptimistic
   If rs.EOF Then
       GetEmployeeName = ""
   Else
       GetEmployeeName = rs.Fields(0)
   End If
   rs.Close
End Function
‘返回所有的雇员列表
Public Function GetEmployeeList() As ADODB.Recordset
   strSql = "select EmployeeID,LastName,FirstName,Title,TitleOfCourtesy,BirthDate,HireDate,Address,City from employees"
   rs.CursorLocation = adUseClient
   Set GetEmployeeList = rs
   rs.Close
End Function
我们进行测试
新建ASP页面,”TestWebDb1.asp”。主要用来测试GetEmployeeList()方法
<HEAD>
<!- 测试页 ->
<!- 功能:测试组件 ->
<!- 作者:龙卷风.NET ->
   Dim strTopic
   Dim strTitle
   Dim strContents
   Dim DataQuery
      Dim Rs
      Dim Myself
      Myself=Request.ServerVariables("script_name")
   Set DataQuery=Server.CreateObject("WebDb.GetInfomation")
      Set Rs=Server.CreateObject("adodb.recordset")
<TITLE>
  数据组件测试页
</TITLE>
<H1><CENTER>欢迎使用数据组件(www.knowsky.com)</CENTER></H1>
      Dim Flag
      Flag=DataQuery.GetConn()
      If Flag=false then
             ResPonse.Write "数据库没有连结,请检查"
             ResPonse.End
      End if
      Set Rs=DataQuery.GetEmployeeList()
      if rs.eof then
             Response.write "没有数据,请查询"
             Response.end
      end if
   Rs.PageSize =3
   Page= CLng(Request.QueryString ("Page"))
   If Page < 1 Then Page = 1
   If Page > Rs.PageCount Then Page = Rs.PageCount
        Response.Write "<CENTER><TABLE BORDER=1 cellspacing=0 cellpadding=2>"
        Response.Write "<tr BGCOLOR=silver align=center>"
        Response.Write "<td>EmployeeID</TD>"
        Response.Write "<td>LastName</td>"
          Response.Write "<td>FirstName</td>"
              Response.Write "<td>Title</a></td>"
          Response.Write "<td>TitleOfCourtesy</a></td>"
          Response.Write "<td>BirthDate</td>"
          Response.Write "<td>HireDate</td>"
          Response.Write "<td>Address</td>"
          Response.Write "<td>City</td>"
        Response.Write "</tr>"
              Rs.AbsolutePage = Page
              For iPage = 1 To Rs.PageSize
                    Response.Write "<TR align=right>"
                  for i=0 to Rs.fields.count-1
                         Response.Write "<td>";Rs.fields.item(i);"</td>"
                     next
                    Response.Write "</TR>"
                     Rs.MoveNext
                     If Rs.EOF Then Exit For
               next
     Response.Write "</TABLE></CENTER>"
<Form name="myform" method="get">
<%If Page <> 1 Then%>
    <A HREF="<%=Myself%>?Page=1">第一页</A>
    <A HREF="<%=Myself%>?Page=<%=(Page-1)%>">上一页</A>
<%End If%>
 <%If Page <> Rs.PageCount Then%>
 <A HREF="<%=Myself%>?Page=<%=(Page+1)%>">下一页</A>
 <A HREF="<%=Myself%>?Page=<%=Rs.PageCount%>">最后的一页</A>
<%End If%>
页次:<FONT COLOR="Red"><%=Page%>/<%=Rs.PageCount%></FONT>
</Form>
Rs.close
新建ASP页面,”TestWebDb2.asp”。主要用来测试GetEmployeeName()方法
这个页面相对简单一些
<HEAD>
<!- 测试页 ->
<!- 功能:测试组件 ->
<!- 作者:龙卷风.NET ->
   Dim DataQuery
      Dim strID
      Dim strResult
<TITLE>
数据组件测试页
</TITLE>
   If Len(Request.QueryString("ID")) > 0 Then
       strID = Request.QueryString("ID")
             Dim Flag
             If Flag=false then
                    ResPonse.End
             End if
             strResult=DataQuery.GetEmployeeName(cint(strID))
             if strResult="" then
                    Response.Write "对不起,没有这个编号,请查询"
                    Response.End
             else
                    ResPonse.Write strResult
             end if
      End If
<FORM NAME="MyForm">
<INPUT TYPE=TEXTBOX NAME="EmpID" SIZE=40><P>
<INPUT LANGUAGE="VBScript"
      TYPE="BUTTON"
      VALUE="Search"
</FORM>
</HEAD>
一些想法:数据库连结如果放到组件里,如果要修改数据库连结,则要重新编译组件,可能会由此引发一些问题(不过推荐这种,毕竟数据库名和服务器名不会经常改)
如果数据库连结放到ASP页面,能通过属性传值到组件中,不过安全性会降低。
真是……
好了,这篇文章结束了,希望对大家有帮助
今后的话题便是怎么实现AspToDll这个软件的功能,我们一步一步实现。
