阅读:3219回复:0
ASP网站如何防止跨站脚本和SQL注入
更多 发布于:2014-04-15 09:27
使用方法如下:
1. 代码直接发出来,大家copy之后,保存为ykmaiz_safe.asp,然后放到站点根目录即可。
02 'Code by kna-tech.com
03 On Error Resume Next
04 if request.querystring<>"" then call stophacker(request.querystring,"'|b(alert|confirm|prompt)b|<[^>]*?>|^+/v(8|9)|bonmouse(over|move)=b|b(and|or)b.+?(>|<|=|binb|blikeb)|/*.+?*/|<s*scriptb|bEXECb|UNION.+?SELECT|UPDATE.+?SET|INSERTs+INTO.+?VALUES|(SELECT|DELETE).+?FROM|(CREATE|ALTER|DROP|TRUNCATE)s+(TABLE|DATABASE)")
05 if Request.ServerVariables("HTTP_REFERER")<>"" then call test(Request.ServerVariables("HTTP_REFERER"),"'|b(and|or)b.+?(>|<|=|binb|blikeb)|/*.+?*/|<s*scriptb|bEXECb|UNION.+?SELECT|UPDATE.+?SET|INSERTs+INTO.+?VALUES|(SELECT|DELETE).+?FROM|(CREATE|ALTER|DROP|TRUNCATE)s+(TABLE|DATABASE)")
06 if request.Cookies<>"" then call stophacker(request.Cookies,"b(and|or)b.{1,6}?(=|>|<|binb|blikeb)|/*.+?*/|<s*scriptb|bEXECb|UNION.+?SELECT|UPDATE.+?SET|INSERTs+INTO.+?VALUES|(SELECT|DELETE).+?FROM|(CREATE|ALTER|DROP|TRUNCATE)s+(TABLE|DATABASE)")
07 call stophacker(request.Form,"^+/v(8|9)|b(and|or)b.{1,6}?(=|>|<|binb|blikeb)|/*.+?*/|<s*scriptb|<s*imgb|bEXECb|UNION.+?SELECT|UPDATE.+?SET|INSERTs+INTO.+?VALUES|(SELECT|DELETE).+?FROM|(CREATE|ALTER|DROP|TRUNCATE)s+(TABLE|DATABASE)")
08
09 function test(values,re)
10 dim regex
11 set regex=new regexp
12 regex.ignorecase = true
13 regex.global = true
14 regex.pattern = re
15 if regex.test(values) then
16 IP=Request.ServerVariables("HTTP_X_FORWARDED_FOR")
17 If IP = "" Then
18 IP=Request.ServerVariables("REMOTE_ADDR")
19 end if
20 'slog("
操作IP: "&ip&"
操作时间: " & now() & "
操作页面:"&Request.ServerVariables("URL")&"
提交方式: "&Request.ServerVariables("Request_Method")&"
提交参数: "&l_get&"
提交数据: "&l_get2)
21 Response.Write("<div style='position:fixed;top:0px;width:100%;height:100%;background-color:white;color:green;font-weight:bold;border-bottom:5px solid #999;'>
您的提交带有不合法参数,谢谢合作!
</div>")
22 Response.end
23 end if
24 set regex = nothing
25 end function
26
27
28 function stophacker(values,re)
29 dim l_get, l_get2,n_get,regex,IP
30 for each n_get in values
31 for each l_get in values
32 l_get2 = values(l_get)
33 set regex = new regexp
34 regex.ignorecase = true
35 regex.global = true
36 regex.pattern = re
37 if regex.test(l_get2) then
38 IP=Request.ServerVariables("HTTP_X_FORWARDED_FOR")
39 If IP = "" Then
40 IP=Request.ServerVariables("REMOTE_ADDR")
41 end if
42 'slog("
操作IP: "&ip&"
操作时间: " & now() & "
提交参数: "&l_get&"
提交数据: "&l_get2)
43 Response.Write("<div style='position:fixed;top:0px;width:100%;height:100%;background-color:white;color:green;font-weight:bold;border-bottom:5px solid #999;'>
您的提交带有不合法参数,谢谢合作!
</div>")
44 Response.end
45 end if
46 set regex = nothing
47 next
48 next
49 end function
50
51 sub slog(logs)
52 dim toppath,fs,Ts
53 toppath = Server.Mappath("/log.htm")
54 Set fs = CreateObject("scripting.filesystemobject")
55 If Not Fs.FILEEXISTS(toppath) Then
56 Set Ts = fs.createtextfile(toppath, True)
57 Ts.close
58 end if
59 Set Ts= Fs.OpenTextFile(toppath,8)
60 Ts.writeline (logs)
61 Ts.Close
62 Set Ts=nothing
63 Set fs=nothing
64 end sub
65
66 %>
2.在所需要防护的页面加入代码
<!--#include virtual="/ykmaiz_safe.asp"-->
就可以做到页面防注入、跨站。
如果想整站防注,就在网站的一个公用文件中,如数据库链接文件conn.asp中!
添加<!--#include virtual="/ykmaiz_safe.asp"-->来调用本代码
很容易,赶快去试试吧!
