阅读:7831回复:0
CentOS安装LNMP之前的系统优化和更新事项
更多 发布于:2014-10-09 10:06
本文总结自己的经验在安装LNMP之前对系统进行必要的优化和更新,LNMP的安装参见《针对VPS的LNMP生产环境:CentOS+Nginx+MySQL+PHP架构配置》。
以下操作只适用于CentOS 5.X
卸载系统自带的httpd、php、mysql等软件
yum -y remove httpd
yum -y remove php
yum -y remove mysql-server mysql
yum -y remove php-mysql更新系统软件和安装必须的软件包
yum -y update
yum -y install gcc gcc-c++ autoconf libjpeg libjpeg-devel libpng libpng-devel freetype freetype-devel libxml2 libxml2-devel zlib zlib-devel glibc glibc-devel glib2 glib2-devel bzip2 bzip2-devel ncurses ncurses-devel curl curl-devel e2fsprogs e2fsprogs-devel krb5 krb5-devel libidn libidn-devel openssl openssl-devel openldap openldap-devel nss_ldap openldap-clients openldap-servers ntp dos2unix保持更新系统时间
echo '*/1 * * * * root /usr/sbin/ntpdate 210.72.145.44 >> /dev/null 2>&1' >> /etc/crontab
service crond restart调整Linux的最大打开的文件数
echo 'ulimit -SHn 65535' >> /etc/rc.local调整TCP/IP网络参数
vim /etc/sysctl.conf添加以下内容
# Add
net.ipv4.tcp_max_syn_backlog = 65536
net.core.netdev_max_backlog = 32768
net.core.somaxconn = 32768
net.core.wmem_default = 8388608
net.core.rmem_default = 8388608
net.core.rmem_max = 16777216
net.core.wmem_max = 16777216
net.ipv4.tcp_timestamps = 0
net.ipv4.tcp_synack_retries = 2
net.ipv4.tcp_syn_retries = 2
net.ipv4.tcp_tw_recycle = 1
#net.ipv4.tcp_tw_len = 1
net.ipv4.tcp_tw_reuse = 1
net.ipv4.tcp_mem = 94500000 915000000 927000000
net.ipv4.tcp_max_orphans = 3276800
#net.ipv4.tcp_fin_timeout = 30
#net.ipv4.tcp_keepalive_time = 120
net.ipv4.ip_local_port_range = 1024 65535使之生效
/sbin/sysctl -p关闭ctrl+alt+del
sed -i "s/ca::ctrlaltdel:/sbin/shutdown -t3 -r now/#ca::ctrlaltdel:/sbin/shutdown -t3 -r now/" /etc/inittab关闭不需要的TTY进程
sed -i 's/3:2345:respawn:/#3:2345:respawn:/' /etc/inittab
sed -i 's/4:2345:respawn:/#4:2345:respawn:/' /etc/inittab
sed -i 's/5:2345:respawn:/#5:2345:respawn:/' /etc/inittab
sed -i 's/6:2345:respawn:/#6:2345:respawn:/' /etc/inittab更改系统命令历史记录为100条
sed -i 's/HISTSIZE=1000/HISTSIZE=100/g' /etc/profile关闭SElinux
sed -i 's/^SELINUX=.*$/SELINUX=disabled/g' /etc/selinux/config优化vim编辑器
sed -i "8 s/^/alias vi='vim'/" /root/.bashrc
echo 'syntax on' > /root/.vimrc关闭暂不需要的系统服务
需要保留的服务:crond、iptables、irqbalance、microcode_ctl、network、random、sshd、syslog、local
可以使用命令:ntsysv 打开选项窗口进行操作,也可以使用以下脚本完成:
for i in `ls /etc/rc3.d/S*`
do
  CURSRV=`echo $i|cut -c 15-`
echo $CURSRV
case $CURSRV in
    crond | iptables | irqbalance | microcode_ctl | network | random | sshd | syslog | local )
    echo "Base services, Skip!"
    echo "change $CURSRV to off"
    chkconfig --level 235 $CURSRV off
    service $CURSRV stop
esac
done
如果是小内存的VPS还需要做:
增加swap交换文件
#创建并激活swap交换文件 cd /var/
dd if=/dev/zero of=swapfile bs=1024 count=262144
/sbin/mkswap swapfile
/sbin/swapon swapfile#加到fstab文件中让系统引导时自动启动 vi /etc/fstab #在末尾增加以下内容: /var/swapfile swap swap defaults 0 0替换系统自带的sendmail为postfix
yum install postfix
service postfix start
chkconfig --level 235 postfix on
