阅读:12980回复:0
IIS 7.5通过web.config设置伪静态规则方法
更多 发布于:2015-01-28 13:36
is7.5下常见程序通过web.config实现伪静态新建一个以web.config命名的文件内容为
<?xml version="1.0" encoding="UTF-8"?>
 <configuration>
     <system.webServer>
 <!--将下面的规则添加到这里-->
     </system.webServer>
 </configuration>
记得后台的伪静态要开启喔
以shopex规则示例如下,选择需要的规则添加:
<!--shopex-->
 <rewrite>
             <rules>
                 <rule name="disableDownloadThemeHtml">
                     <match url="^themes/.*.(html|xml)$" ignoreCase="false" />
                     <action type="CustomResponse" url="/" statusCode="403" statusReason="Forbidden" statusDescription="Forbidden" />
                 </rule>
                 <rule name="urlRewrite">
                     <match url="^(.*)$" ignoreCase="false" />
                     <conditions logicalGrouping="MatchAll">
                         <add input="{REQUEST_FILENAME}" pattern=".(html|xml|json|htm|php|php2|php3|php4|php5|phtml|pwml|inc|asp|aspx|ascx|jsp|cfm|cfc|pl|cgi|shtml|shtm|phtm)$" ignoreCase="false" />
                         <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" pattern="" ignoreCase="false" />
                         <add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" pattern="" ignoreCase="false" />
                     </conditions>
                     <action type="Rewrite" url="index.php?{R:1}" appendQueryString="false" />
                 </rule>
             </rules>
         </rewrite>
 <!--dz2.0-->
 <rewrite>
 <rules>
   <rule name="portal_topic">
    <match url="^(.*/)*topic-(.+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/portal.php?mod=topic&amp;topic={R:2}&amp;{R:3}" />
   </rule>
   <rule name="portal_article">
    <match url="^(.*/)*article-([0-9]+)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/portal.php?mod=view&amp;aid={R:2}&amp;page={R:3}&amp;{R:4}" />
   </rule>
   <rule name="forum_forumdisplay">
    <match url="^(.*/)*forum-(w+)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/forum.php?mod=forumdisplay&amp;fid={R:2}&amp;page={R:3}&amp;{R:4}" />
   </rule>
   <rule name="forum_viewthread">
    <match url="^(.*/)*thread-([0-9]+)-([0-9]+)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/forum.php?mod=viewthread&amp;tid={R:2}&amp;extra=page={R:4}&amp;page={R:3}&amp;{R:5}" />
   </rule>
   <rule name="group_group">
    <match url="^(.*/)*group-([0-9]+)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/forum.php?mod=group&amp;fid={R:2}&amp;page={R:3}&amp;{R:4}" />
   </rule>
   <rule name="home_space">
    <match url="^(.*/)*space-(username|uid)-(.+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/home.php?mod=space&amp;{R:2}={R:3}&amp;{R:4}" />
   </rule>
   <rule name="home_blog">
    <match url="^(.*/)*blog-([0-9]+)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/home.php?mod=space&amp;uid={R:2}&amp;do=blog&amp;id={R:3}&amp;{R:4}" />
   </rule>
   <rule name="forum_archiver">
    <match url="^(.*/)*(fid|tid)-([0-9]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/index.php?action={R:2}&amp;value={R:3}&amp;{R:4}" />
   </rule>
 </rules>
 </rewrite>
 <!--dz2.5-->
 <rewrite>
 <rules>
   </rule>
   </rule>
   </rule>
   </rule>
   </rule>
   </rule>
   </rule>
   </rule>
   <rule name="plugin">
    <match url="^(.*/)*([a-z]+[a-z0-9_]*)-([a-z0-9_-]+).html?*(.*)$" />
    <action type="Rewrite" url="{R:1}/plugin.php?id={R:2}:{R:3}&amp;{R:4}" />
   </rule>
 </rules>
 </rewrite>
