532628838
圣骑士
圣骑士
  • 注册日期2011-06-10
  • 发帖数98
  • 火币517枚
  • 粉丝77
  • 关注39
阅读:3854回复:0
基础汇编试题
更多 发布于:2011-08-01 16:32
一个基础的汇编例题,要求用汇编语言实现R<-X+Y-3
    其中R·X·Y都是字数组,要求X,Y放在D_SEG段,R放在E_SEG段
D_SEG segment
    x dw 200,241,308,102,1247
    y dw 20,25,2530,888,356
D_SEG ends
E_SEG segment
    r dw 5 dup(?)
E_SEG ends
datagroup group D_SEG,E_SEG
code segment
    assume cs:code,ds:datagroup
main proc far
    mov ax,datagroup
    mov ds,ax
    call compute
    mov ax,4c00h
    int 21h
main endp
compute proc near
    mov cx,5
    mov si,0
next:
    mov ax,x[si]
    add ax,y[si]
    sub ax,3
    mov r[si],ax
    add si,2
    loop next
    mov cx,5
    add di,0
net:
    mov bx,r[di]
    push cx
    call put
    call crlf
    add di,2
    pop cx
    loop net
    ret
compute endp
put proc near
    mov cx,10000d
    call output
    mov cx,1000d
    call output
    mov cx,100d
    call output
    mov cx,10d
    call output
    mov cx,1d
    call output
    ret
put endp
output proc near
    mov ax,bx
    mov dx,0
    div cx
    mov bx,dx
    mov dl,al
    add dl,30h
mov ah,2
    int 21h
    ret
output endp
crlf proc near
    mov dl,0ah
    mov ah,2
    int 21h
    mov dl,0dh
    mov ah,2
    int 21h
    ret
crlf endp
code ends
end main
