532628838
圣骑士
圣骑士
  • 注册日期2011-06-10
  • 发帖数98
  • 火币517枚
  • 粉丝77
  • 关注39
阅读:5595回复:0
[ACCESS]ACCESS中重新定位链接表二步走
更多 发布于:2011-08-01 17:17
假设前台数据库文件名为frontBase.mdb
后台数据库文件名为backData.mdb
frontBase当中有链接表tbl1, tbl2, tbl3, …,链接到backData.mdb中
首先我们要在前台数据库文件的启动窗体加载事件中判断链接是否正确
方法是打开任意一个链接表,假设为tbl1,代码如下:
Public Function CheckLinks() As Boolean
’ 检查到后台数据库的链接;如果链接存在且正确的话,返回 True 。
   Dim dbs As Database, rst As DAO.Recordset
   Set dbs = CurrentDb()
   ’ 打开链接表查看表链接信息是否正确。
   On Error Resume Next
   Set rst = dbs.OpenRecordset(“tbl1”)
   rst.Close
   ’ 如果没有错误,返回 True 。
   If Err = 0 Then
     CheckLinks = True
   Else
     CheckLinks = False
   End If
End Function
启动窗体的加载事件:
Private Sub FORM_Load()
If CheckLinks = False then
Docmd.OpenFORM “frmConnect”
End If
End Sub
frmConnect 连接窗体如下图
接下来的事情就是如何刷新链接表了。
上面的窗体右边的按钮是用用来调用API打开文件对话框,具体代码如下:
Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Boolean
Type OPENFILENAME
   lStructSize As Long
   hwndOwner As Long
   hInstance As Long
   lpstrFilter As String
   lpstrCustomFilter As String
   nMaxCustFilter As Long
   nFilterIndex As Long
   lpstrFile As String
   nMaxFile As Long
   lpstrFileTitle As String
   nMaxFileTitle As Long
   lpstrInitialDir As String
   lpstrTitle As String
   flags As Long
   nFileOffset As Integer
   nFileExtension As Integer
   lpstrDefExt As String
   lCustData As Long
   lpfnHook As Long
   lpTemplateName As String
End Type
Private Sub FileOpen_Click()
  Dim ofn As OPENFILENAME
  Dim rtn As String
  ofn.lStructSize = Len(ofn)
  ofn.hwndOwner = Me.hwnd
  ofn.lpstrFilter = "数据库文件 (*.mdb)" ; vbNullChar ; "*.mdb"
  ofn.lpstrFile = Space(254)
  ofn.nMaxFile = 255
  ofn.lpstrFileTitle = Space(254)
  ofn.nMaxFileTitle = 255
  ofn.lpstrInitialDir = CurrentProject.Path
  ofn.lpstrTitle = "后台数据文件为"
  ofn.flags = 6148
  rtn = GetOpenFileName(ofn)
  FileName.SetFocus
  If rtn = True Then
    FileName.Text = ofn.lpstrFile
    FileName.Text = FileName.Text
    OK.Enabled = True
  Else
    FileName.Text = ""
  End If
End Sub
连接按钮刷新链接表 ,代码如下:
Private Sub OK_Click()
Dim tabDef As TableDef
For Each tabDef In CurrentDb.TableDefs
If Len(tabDef.Connect) > 0 Then
tabDef.Connect = ";DATABASE=" ; Me.FileName.Text ; ";PWD=" + 后台数据库密码
tabDef.RefreshLink
End If
Next
MsgBox "连接成功!"
DoCmd.Close acFORM, Me.Name
End Sub
其实很简单只有两步,判断链接是否正确和刷新链接表。
