532628838
圣骑士
圣骑士
  • 注册日期2011-06-10
  • 发帖数98
  • 火币517枚
  • 粉丝77
  • 关注39
阅读:4978回复:0
[ACCESS]ACCESS中自定义链接后端数据库
更多 发布于:2011-08-01 17:24
代码很简单的,我这里的例子是从文本框里输入新的数据库路径,然后更新链接。你参考一下,再改。
Private Sub Command0_Click()
On Error GoTo Err_Command0_Click
Dim cat As ADOX.Catalog
Dim tdf As ADOX.Table
Me.txtDBnewNAME.SetFocus
Set cat = New ADOX.Catalog
Set cat.ActiveConnection = CurrentProject.Connection
Set tdf = cat.Tables("mytable")
tdf.Properties("jet oledb:link datasource") = Me.txtDBnewNAME.Text
Exit_Command0_Click:
Exit Sub
Err_Command0_Click:
MsgBox Err.Description
Resume Exit_Command0_Click
End Sub
