阅读:3690回复:0
用Flash AS3制作统计饼图动画效果
更多 发布于:2011-08-16 03:11
说明:点击的蓝色按钮可以画出各种饼图,点击饼图中不同色块可以观看效果。
代码如下:
* @class:DrawPieGraph(画饼状图)
* @author:ycccc8202
* @date:2007.8.16
* @example:
* import com.ycccc.Graphics.*;
* var dataList:Array=[10,10,10,100,10,10,10,100];
* var pie:DrawPieGraph=new DrawPieGraph(200,200,150,90,15,dataList,[0xFF0F00,0xFF6600,0xFF9E01,0xFCD202,0xF8FF01,0xB0DE09,0x04D215,0x0D8ECF],.7);
* addChild(sprite);
package com.ycccc.Graphics{
import fl.transitions.Tween;
import fl.transitions.easing.*;
import fl.transitions.TweenEvent;
import flash.display.MovieClip;
import flash.display.Sprite;
import flash.display.Shape;
import flash.display.Graphics;
import flash.events.MouseEvent;
public class DrawPieGraph extends MovieClip {
  //存放shape对象
  private var __contain:Object;
  //设置角度从-90开始
  private var R:int=-90;
  private var D:uint=20;
  private var _shape:Shape;
  //初始饼图的圆心位置
  private var _x0:Number;
  private var _y0:Number;
  //椭圆饼图的长轴与短轴长度
  private var _a:Number;
  private var _b:Number;
  //饼图的厚度
  private var _h:Number;
  //透明度
  private var _alpha:Number
  //数据列表
  private var _dataList:Array;
  private var _colorList:Array;
  private var _angleList:Array;
  private var _depthList:Array;
  *@param:x0......>圆心x坐标
  *@param:y0......>圆心y坐标
  *@param:a......>长轴
  *@param:b......>短轴
  *@param:h......>厚度
  *@param:dataList......>数据列表
  *@param:dataList......>颜色列表
  *@alpha:Number......>透明度,默认为1.0
  public function DrawPieGraph(x0:Number,y0:Number,a:Number,b:Number,h:Number,
dataList:Array,colorList:Array,alpha:Number=1.0) {
   _x0=x0;
   _y0=y0;
   _a=a;
   _b=b;
   _h=h;
   _alpha=alpha
   _dataList=dataList;
   _colorList=colorList;
   setAngleList();
   drawPie();
   setDepths();
  private function setAngleList():void {
   _angleList=[];
   var totalData:int;
   var len:uint=_dataList.length;
   for (var j:uint=0; j < len; j++) {
    totalData+= _dataList[j];
   for (j=0; j < len; j++) {
    if (j == len - 1) {
     _angleList.push([R,270]);
    } else {
     var r:uint=Math.floor(_dataList[j] / totalData * 360);
     var posR:int=R + r;
     _angleList.push([R,posR]);
     R=posR;
     trace(r+"___r");
     trace(R);
   trace(_angleList + ":::");
  private function setDepths():void {
   _depthList=[];
   var len:uint=_angleList.length;
    var minJ:Number=_angleList[j][0];
    var maxJ:Number=_angleList[j][1];
    switch (true) {
     case minJ >= -90 ;; minJ <= 90 ;; maxJ<=90 :
      _depthList[j]=minJ;
      break;
     default :
      _depthList[j]=1000-minJ;
   }//end for
   trace(_depthList + "::::_depthList");
   _depthList=_depthList.sort(Array.NUMERIC | Array.RETURNINDEXEDARRAY);
   trace(_depthList);
   for (j=0; j
