网页设计
net技术
asp.net 利用RAR实现文件压缩解压缩
schack8888
风云使者
3641枚
发布于:2011-08-16 12:38
如果服务器上安装了RAR程序,那么asp.net可以调用RAR实现文件压缩与解压缩。
不过要注意的是,由于
web
程序不能直接调用客户端的程序(除非用ActiveX,ActiveX几乎被废弃),所以如果要想实现让用户把本地文件用网页解压缩只有把文件上传到服务器上再调用服务器上的RAR压缩,同理要解压缩本地的RAR文件可以把文件上传到服务器解压再拿回来。
本文讲怎么在服务器端的目录解压缩文件!
前台代码:
[color=#990000;]以下是引用片段:
后台代码:
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.IO;
using System.Runtime.
inter
opServices;
using Microsoft.Win32;
using System.Diagnostics;
public partial class _Default : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
//清清月儿
http://blog.csdn.net/21aspnet/
protected void Button1_Click(object sender, EventArgs e)
//压缩
String the_rar;
RegistryKey the_Reg;
Object the_Obj;
String the_Info;
ProcessStartInfo the_StartInfo;
Process the_Process;
try
the_Reg = Registry.ClassesRoot.OpenSubKey("Applications\WinRAR.exe\Shell\Open\Command");
the_Obj = the_Reg.GetValue("");
the_rar = the_Obj.ToString();
the_Reg.Close();
the_rar = the_rar.Substring(1, the_rar.Length - 7);
the_Info = " a " + " 1.rar " + " " + "C:\1\1.txt";
the_StartInfo = new ProcessStartInfo();
the_StartInfo.FileName = the_rar;
the_StartInfo.Arguments = the_Info;
the_StartInfo.WindowStyle = ProcessWindowStyle.Hidden;
the_StartInfo.WorkingDirectory = "C:\1";//获取或设置要启动的进程的初始目录。
the_Process = new Process();
the_Process.StartInfo = the_StartInfo;
the_Process.Start();
Response.Write("压缩成功");
catch (Exception ex)
Response.Write(ex.ToString());
protected void Button2_Click(object sender, EventArgs e)
//解压缩
String the_rar;
Object the_Obj;
String the_Info;
try
the_Reg = Registry.ClassesRoot.OpenSubKey("Applications\WinRar.exe\Shell\Open\Command");
the_Reg.Close();
the_Info = " X " + " 1.rar " + " " + "C:\1";
Response.Write("解压缩成功");
兼职版主
